Shower Build Question Not Sure Wher To Ask - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 10-02-2012, 10:42 PM   #1
Rewards Points: 50
Shower build question not sure wher to ask
Total gut and bath remodel. In the shower, is it ok and acceptable to just use 1/2 inch hardie backer? Over studs?
Going to use the Kerdie process for completion.
Post moved to tile forum
digitalplumber is just a name for use here, I am not a plumber!
Last edited by BigJim; 10-03-2012 at 08:06 AM. Reason: More attention in correct forum
digitalplumber is offline   Reply With Quote
Old 10-03-2012, 01:27 AM   #2
Re: Shower Build
Hi DP
On the shower walls yes. On the shower floor, NO!
I am in the final stretch of doing a total demo and rebuild and used HB 500 as my substrate. As long as your framing is sound, straight and level 2x4's with a maximum 16" space from center on your studs, you'll be fine. Make sure your framing has adequate corners to attach the HB too. Leave a 1/4" seam at the base and a min 1/8" on the seams.
Also since you are using Kerdie, don't put a vapor barrier behind the HB as you will just trap moisture in your wall. The Kerdie is waterproof and considered a topical Vapor Barrier.
HB is a pain to cut. You have to score the hell out of it with a carbide tip cutter and snap it towards you. The snapped surface looks like a topographical map of the Sierra's and will require sanding for a flush fit. If you take a saw to it. One it will eat up normal blades and two, the dust it creates is volcanic and dangerous (Silica)
Had I known then what I know now i'd have gone with
http://www.schluterkerdiboard.com
I'm just an avid DIYer with about 10 successful projects under my belt. So let's see if the pro's have a different opinion.
Good Luck
RWPete is offline   Reply With Quote
Old 10-03-2012, 01:30 AM   #3
Rewards Points: 50
Thanks. Swathe kerdi board but it's pretty stout in price. Thank going to use the shower kit .
Old 10-17-2012, 08:50 AM   #4
REDRUM's Avatar
you can do it without kerdi...
vapor barrier + 1/2" hb on studs (walls) & fiberglass pan, or traditional mud/tile pan
REDRUM is offline   Reply With Quote
The Following User Says Thank You to REDRUM For This Useful Post:
digitalplumber (10-17-2012)
Old 10-17-2012, 08:59 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 290
Sure he could, but, he wants a higher quality shower than the old traditional ones. One that is completely waterproof, both floor and walls, with vapor barrier. Because of the surface membrane it'll dry quickly between uses therefore will look better after many years of use.
Jaz
Shower Pan Question SER56 Kitchen & Bath Remodeling 6 03-22-2012 01:29 PM
Tiling a Shower thinset question Dangchores Tiling, ceramics, marble 3 03-01-2012 04:04 PM
1st time shower build, please take a look vgoose Kitchen & Bath Remodeling 6 06-24-2010 12:59 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
How to build base for a shower stall atm Plumbing 13 05-13-2009 11:18 AM
