Shower Bench Seats - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 01-07-2013, 11:19 PM   #1
Shower bench seats
Please give me your opinions and why.
I would like to know which option is best and most waterproof.
Installation of a shower bench:
Is it best...
1. wood bench with pvc shower liner over it then tile ...or
2. pvc liner first then make a seat with bricks then tile.
ladytiler is offline   Reply With Quote
Old 01-08-2013, 05:25 AM   #2
DIY staff
Rewards Points: 7,174
The trouble with a PVC liner under a bench----How are you going to nail in the tile backer board without punching holes in the liner?
Here's a thought---go ahead and use a liner---then add the backer---then use a surface water proofer lie Hydroban--or Red Guard-- or Aqua Defense ---then tile---
Old 01-08-2013, 09:40 AM   #3
[QUOTE=oh'mike;1088831]The trouble with a PVC liner under a bench----How are you goin
Thought it would be mudded in over the brick
Old 01-08-2013, 09:50 AM   #4
DIY staff
I think you may be over thinking this----typical membrane pan with seat has wood framing for seat--then a 3/4" plywood skin---Durrock over the skin--then a surface membrane over the Durrock
How to build a shower - Building a shower pan with pre-sloped mortar bed, liner and curb.
Tile and grout are not water proof---something must be used to keep the water that gets through from entering the wood framework---brick and mortar are not waterproof either---nor is a membrane with nails or screw holes----
Tell us more about what you have in mind--also go to Latacrete's site and look at Hydroban---
ladytiler (01-08-2013)
Old 01-08-2013, 10:41 AM   #5
tile shower bench bluebird5 Flooring 6 02-13-2011 09:35 PM
Suggested Shower Bench Dimensions spQQk Building & Construction 5 03-07-2009 08:05 AM
Bench seat in a tile shower mikewrx Remodeling 1 03-23-2008 08:11 PM
Retiling Shower Bench - HELP Jamboy Remodeling 4 10-09-2007 10:03 AM
Retiling Shower Bench - HELP Jamboy Building & Construction 2 10-07-2007 11:56 AM
