Should I Seal My Shower Tile Grout? - Tiling, ceramics, marble - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-12-2009, 03:49 PM   #16
Originally Posted by Bud Cline View Post
The grout you used has a name. It says more on the label than just "pre-mixed grout". MAN...it's like pulling teeth around here trying to get the necessary information it takes to offer someone a skilled professional informed answer to their question.
[IMG]file:///C:/Users/steve/AppData/Local/Temp/moz-screenshot.png[/IMG]
This is what it is??
Limit54 is offline   Reply With Quote
Old 12-12-2009, 08:39 PM   #17
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I just learned something! I didn't know Mapei had jumped on that bandwagon.
Here's your answer:
http://www.mapei.it/Referenze/Multim...out_TDS_EA.pdf
This is the first I have seen or heard of that product.
I might add that during my search I ran into many negative comments about the performance of that product.
XXX
Old 12-12-2009, 10:05 PM   #18
I can assure you that this grout is absolutely crap...it dries rock hard in like 2 minutes and is so hard to remove the haze. I dont recommend it be used on polished marble. It also doesn't go on very well after using a sponge. i had to grout twice and it's not like I haven't grouted before. I have grouted about 5 times and never have had to do it twice.
Anyway there is nothing I can do about it now.
what i want to know is what type of grout should i be using for this application.
Thanks.
Old 12-13-2009, 07:02 AM   #19
Any cement based grout you mix yourself.
R&D Tile is offline   Reply With Quote
Old 12-13-2009, 07:34 AM   #20
ccarlisle's Avatar
Boy! those are narrow specifications for application and use..."intermittent wet areas"...huh? I see you have to moisten the surface you are about to grout first before grouting. So, tell us Limit54, did you do that?
I wonder if there is any cement in there at all...it sounds almost epoxy-like, in taking so long to cure before traffic etc. I really wonder if this isn't a real DIY product that most people who tile for a living wouldn't even touch.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 12-13-2009, 08:24 AM   #21
No i did not moisten the area before grouting.
Old 12-13-2009, 08:40 AM   #22
ccarlisle's Avatar
Well, that may be why you had less-than-optimal performance from your grout. Some stones and tiles are quite absorbent of different fluids and the reason some tilers like to seal their tiles on the sides before grouting - just to prevent any migration of, say, water, that would otherwise be there to manage the controlled hardening rate of the grout.
Just like cement: it has to dry at a controlled rate - not too fast , not too slow. Main reason you see newly-poured concrete covered up during the summer months...
I am not familiar with this product (although I know Mapei) but I am only suggesting that too little water might be the cause for the quick hardening and therefore the haze you might have had.
Old 12-13-2009, 09:56 AM   #23
you know what you are probably right. The thing is that I've never had to go to the manufacturers web site and read the PDF...but I guess I should from now on. usually this stuff is printed on the packaging or it comes with a leaflet.
My purpose of buying this stuff, as I was skeptical was that it was made by Mapie and I trust them in terms of product.
anyway, all in all it worked and its just taking a little more work to get right. My tile is not damaged and that the main thing.
I like the tip about sealing the sides of the tile...Something I would never have thought about.
Once again i love this place.
Old 12-13-2009, 10:23 AM   #24
ccarlisle's Avatar
Yeah, me too.
Sealing natural stone tile edges is one area I have no reservations about doing. It seems simple enough and a lot more sensible than some applications of sealers. In these days of cheap stones and multi-coloured grouts and grout colour-sealing, it is an insurance policy againt failures due to discolouration - and IMO any means you can find to reduce the risk associated with putting down a stone floor, the better...
Cracking floor grout - Ceramic tile DeepDish Building & Construction 9 08-27-2008 09:51 PM
Cracking Grout Between Shower Tiles average General DIY Discussions 9 05-08-2007 02:20 PM
Cracking floor grout - Ceramic tile DeepDish Flooring 9 03-03-2007 07:49 PM
Can you caulk over grout lines in a tile shower? Greg General DIY Discussions 7 11-20-2006 05:20 PM
