-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   Should I Kerdi or not? (http://www.diychatroom.com/f84/should-i-kerdi-not-89992/)
BigMan926 12-19-2010 07:57 PM
Hi everyone. I'm a reasonably experienced weekend warrior and have tackled many home improvement / renovation projects but I'm new to these forums and I have a question. I'm upgrading a very old master ensuite and I've recently installed and drywalled a new larger tub where an old smaller used to be. Before I tackle the tiling around the shower I was wondering if it's a MUST DO to install waterproofing membrane (ie. Kerdi) before I tile?
Thanks for your input.
secutanudu 12-19-2010 09:13 PM
It's not a MUST DO...I think it's more important for showers with a tiled floor...
That being said, the stuff is pretty awesome when applied correctly. Make sure you use unmodified thinset (no latex) additive if you use kerdi, I believe on both sides of the membrane. And soak the wall with water before you do it (though this is more important for concrete board).
Termite 12-20-2010 12:57 AM
If you drywalled a wet area then I would consider Kerdi a must do. If you used cement backerboard then I'd say it is an option, but some sort of waterproofing layer between the board and the tile is a must. Redguard is a cheaper option, but not on drywall. Drywall under tile in wet areas is a code violation in many, many areas nowadays, for good reason. Kerdi can be applied over drywall and will render it as waterproof as a frog's butt. Without Kerdi your only option is removal of the drywall and re-hanging the wall with wonderboard/durarock, then application of Redguard or similar paint-on waterproofer.
If you hang tile straight to drywall in a shower/tub area, you're guaranteed to have to re-do the job within a few years. Not to mention the moisture in the wall.
secutanudu 12-20-2010 07:32 AM
Yeah, I agree with thekctermite. I wasnt thinking about it not being concrete board...
BigMan926 12-21-2010 04:07 PM
Thanks for all your feedback...I'm convinced...Kerdi is a MUST do.
