Sharp Corner - Shower Tile - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-24-2012, 01:38 PM   #1
Rewards Points: 206
Sharp corner - shower tile
One floor tile in the shower has a sharp corner that sticks up.
What tool/method can I use to grind/file/sand it down?
Sorry for the fuzzy picture.
John_W is offline   Reply With Quote
Old 05-24-2012, 03:02 PM   #2
MarginallyQualified
Rewards Points: 2,464
You'll probably be better off lifting it out...
and either resetting it or putting something else in the void.
Old 05-24-2012, 06:41 PM   #3
Rewards Points: 1,062
right. but temporarily, you can sand it down with emory paper- about 80 grit. Wrap it around a small wood block and then sand. Yes, it will chew off that sharp edge. dont give up in one minute, though......
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
The Following User Says Thank You to noquacks For This Useful Post:
John_W (05-24-2012)
Old 05-24-2012, 06:59 PM   #4
DIY staff
Rewards Points: 7,174
A diamond wheel in a Dremmel will work --If you have one--
John_W (05-24-2012)
Removing Corner Shower Tile (with pictures) JasonCA Kitchen & Bath Remodeling 16 03-30-2012 09:19 PM
Shower pan/ tile problem Pawl Tiling, ceramics, marble 8 01-16-2012 09:32 AM
Shower Tile Issues Clover Plumbing 0 11-11-2011 08:54 PM
Repairing ceramic tile shower jimmyj Building & Construction 1 04-25-2011 08:09 PM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
