Setting 1''x1'' Sheets On A Shower Floor - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 11-18-2012, 08:29 PM   #1
Rewards Points: 340
setting 1''x1'' sheets on a shower floor
Can I use grout to set the sheets on my shower floor?
the thinset keeps pushing up thru the tiles and I have to use elbow grease to clean the thinset out so I can grout.
and while I an asking if I use Custom's REDGARD ,is the thinset applied directly on the Redgard ?
kt82 is offline   Reply With Quote
Old 11-19-2012, 01:59 PM   #2
Now I'm no expert, but my shower is done with 1"x 1" tiles on 12" x 12" sheets. Mortar that came up through got sanded with a grout saw for grout. 2 years all good and no leaks
r.mills is offline   Reply With Quote
Old 11-20-2012, 06:46 AM   #3
Rewards Points: 340
Did your sheets have places were the glue on the mesh was in the joints?
Old 11-20-2012, 08:58 AM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Use thinset, not grout, to set tiles.
Remove the excess thinset right away. It is easy to remove while it is wet. Once it dries and hardens it is a lot more difficult.
If you used Redgard on the walls, yes, tile directly on the Redgard.
The Following User Says Thank You to Blondesense For This Useful Post:
kt82 (11-20-2012)
Old 11-20-2012, 09:56 AM   #5
Rewards Points: 13,968
Sounds like you may be using to much thinset.
Are you using a toothed trowl?
kt82 (11-20-2012)
Old 11-20-2012, 11:40 AM   #6
Rewards Points: 150
use way less thinset. I had the same issue with some accent tiles recently, the less thinset I used, the better and easier they were to install.
Squished is offline   Reply With Quote
The Following User Says Thank You to Squished For This Useful Post:
kt82 (11-20-2012)
Old 11-20-2012, 03:02 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
No.
This is because you are using the WRONG TROWEL.
Yes.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
kt82 (11-20-2012)
tiling a shower floor ratherbefishing Kitchen & Bath Remodeling 4 04-08-2012 11:15 PM
Shower Floor Grout Prob. MEH Tiling, ceramics, marble 1 11-05-2010 07:55 PM
Piece of junk, leaky shower. How can I improve it? JustinEllard Plumbing 4 10-05-2010 08:45 AM
water leak on tile shower floor redskins Plumbing 1 07-18-2009 05:58 AM
Busting out my shower tile floor and walls. caliskier Building & Construction 3 03-15-2009 08:59 AM
