Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 12-10-2012, 08:17 AM   #1
Self Stick Vinyl Tile for Backsplash Issues
The self-stick vinyl tile being used as a kitchen backsplash will not stay stuck to the wall, even after the wall was primed using the product recommended by the seller of the tiles. What can I use to get the tiles to stay stuck??
Sandra Veltkamp is offline   Reply With Quote
Old 12-10-2012, 08:33 AM   #2
And you degreased the whole area and lightly sanded it before applying, right.
If it was mine I never would have even tryed using stick it up and hope for the best tiles.
I've just seen way to any peel and sticks fail. One of those things that sounds good on paper.
Old 12-10-2012, 05:01 PM   #3
Tileguy
JazMan's Avatar
Sandra,
Peel & Stik floor tiles will not stick vertically, it's not made for that. The adhesive is pressure sensitive and requires its own weight to bond. Bad idea to use it on walls.
If you still want to use it, get a thick adhesive like cove base adhesive. That will work, but I still think it's not a good idea especially behind the range.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Anyone install Menard's Designer's Image Luxury Vinyl Tile? Studly Flooring 4 11-18-2012 08:53 PM
adhesive removal from vinyl tile cleaninglady Flooring 0 08-24-2012 12:21 PM
peel and stick vinyl tile fanner Flooring 1 03-03-2011 05:05 PM
New porcelain tile to replace vinyl floor in kitchen PatrickGSR94 Flooring 5 03-03-2011 02:42 PM
