Self Leveling Concrete Gone Wrong - Two Layers - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-05-2014, 08:11 AM   #1
Self leveling concrete gone wrong - two layers
Hi,
My contractor tried to pour self leveling concrete in the bathroom before tiling it with 32"x8" porcelain tiles. He ran out of concrete before he finished the job. The following day he continued pouring the self leveling concrete. The result is two layers of different height with a noticeable step between them. See pictures (tiles in the pictures are not adhered to the floor yet - just there so we can see the layout).
Can the floor be tiled in this situation or should I demand that he fix it by removing the 2nd layer or pouring another thin layer to make the floor flat?
Ronen
Self leveling concrete gone wrong - two layers-photo-1.jpg   Self leveling concrete gone wrong - two layers-photo-2.jpg   Self leveling concrete gone wrong - two layers-photo-3.jpg
ronenbar is offline   Reply With Quote
Old 08-05-2014, 10:28 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You don't want to install tile the way it is! At the very least it needs to be ground down and flattened.
XXX
Old 08-05-2014, 12:58 PM   #3
Rewards Points: 144
+1 It needs to be perfectly flat.Especially with those large tiles.
mako1 is offline   Reply With Quote
Old 08-05-2014, 03:52 PM   #4
Rewards Points: 402
Look at that first picture you have, where the tile goes from one layer to the next. You can see the gap under the tile where it transitions to the 2nd layer of concrete. Not good at all. You should be able to point that out and that should be enough of a reason to get it fixed.
taylorjm is offline   Reply With Quote
Grinding concrete that has self leveling on BlueBSH Concrete, Stone & Masonry 2 10-16-2013 09:51 PM
Leveling a concrete floor in converted den? WNB Flooring 0 08-20-2013 11:31 AM
Self leveling concrete questions Dave K Flooring 3 08-21-2011 05:49 AM
concrete leveling grainbelt Flooring 5 12-12-2009 08:41 PM
