Sealing Grout For Outdoor Granite Sidewalk - Tiling, ceramics, marble - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-16-2009, 01:22 PM   #16
TVM
Sand instead of grout ... what if there's a cement bed beneath
Thank you again.
There's a possibility that the granite slabs sit on a cement bed (when I dug along the edge of the sidwalk last summer to run sprinkler tubing I encountered what appeared to be cemented gravel on the underside of the walkway). It may be the case that this is there simply to cement in the outside border of belgian blocks. HOWEVER, if the granite slabs are on a cement/concrete base, can I simply pour sand on top and relay the slabs, or would I need to jack-hammer up and remove the concrete?
TVM is offline   Reply With Quote
Old 02-16-2009, 06:58 PM   #17
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You can lead a horse to water.......... BUT you........
If the stones are "heaving" it is likely because you don't have proper drainage. Freezing will cause the stones to heave but only if moisture is abundant. If the stones where installed on a proper bed of gravel (to allow for drainage) and then sand to properly "bed" the stones, the problem would be less of an issue.
At any rate - you are wasting your time trying to keep grout in tact if you aren't willing to install the stones properly. And even then it is a gamble. You are dealing with a natural phenomenon and in reality there is little you can do about it.
Now, I'm going to go sit with yes it's concrete and Carlisle and silently enjoy the rest of the show.
Old 02-16-2009, 07:09 PM   #18
TVM
Well, my wife would concur that I am dense...but I am not so dense as to not be appreciative. Thank you all for your input and suggestions.
Tags
granite , grout , outdoor , sealer , sidewalk
Sealing Grout qvminich Building & Construction 4 08-24-2008 05:56 PM
sealing tile grout questions 4just1don Remodeling 5 06-27-2008 05:37 PM
Sealing grout Crysgrits Flooring 2 02-26-2008 03:13 PM
sealing grout, how many coats? Yeti Flooring 1 10-19-2007 10:23 PM
sealing crack sidewalk cmb1128 General DIY Discussions 2 10-13-2007 03:22 PM
