Which Sealer To Use That Will Slightly Darken Grout? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-27-2010, 11:32 AM   #1
Which sealer to use that will slightly darken grout?
Just finished tiling our bathroom floor, and I'd like to darker the grout a little if I can. I say this because the thinset we used was slightly darker than the grout itself, and there are a few small areas that appear it has bleed through.
Can anyone recommend a sealant that would do this?
HenryG is offline   Reply With Quote
Old 02-27-2010, 11:33 AM   #2
Here is a photo of the job...
Old 02-28-2010, 11:36 AM   #3
Tileguy
JazMan's Avatar
Rewards Points: 388
There's enhancing sealers that will darken the grout, but I doubt that's going to make your grout look much better. You should dig-out the thin set that show through. Next time, and for others, clean as you go.
Jaz
Old 02-28-2010, 06:45 PM   #4
Jaz
Dig out the spots, then re apply the grout?
Old 02-28-2010, 06:46 PM   #5
Military Mom of 4
Snav's Avatar
Just get some grout-color, it's a paint-like liquid you apply to change the color and you can seal overtop of it.
Your bathroom looks familiar - did you recently post about it in which it went into a discussion about premixed VS powdered thinset?
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 02-28-2010, 08:41 PM   #6
How easy is it to apply? Is it something I can wipe over the entire surface of the tile, and wipe away the excess?
I did make a thread about leveling the floor beforehand and there was some discussion on premixed vs regular thinset. This is all new to me, and just mixing it myself was actually really easy.
So far so good on this project.. I should be tiling the shower area soon.
Grout sealer before or after silicone caulk ? SPS-1 General DIY Discussions 2 07-28-2009 09:30 AM
Applying grout sealer on vertical wall tiles MT Stringer Remodeling 2 06-02-2009 05:17 PM
What type of grout and sealer is the best for flooring skullface Flooring 4 06-01-2009 10:00 PM
Sealing grout for outdoor granite sidewalk TVM Tiling, ceramics, marble 17 02-16-2009 07:09 PM
wet space grout sealer help irlizard Flooring 2 08-15-2006 05:13 PM
