Which Sealant For Tile Grout? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-19-2012, 05:18 PM   #1
Rewards Points: 363
Which Sealant for Tile Grout?
I have some glazed ceramic tile and some unsanded grout. This will be used to tile a floor.
I noticed online there is a membrane forming sealant, and a penetrating sealant. When I went to the store, I noticed there was gloss and unglossed sealant.
What type of sealant do I need to buy?
I will also seal my kitchen sink area. Will the same sealant work in the kitchen sink area and on the floor?
greentrees is offline   Reply With Quote
Old 05-19-2012, 07:20 PM   #2
Pro
JetSwet's Avatar
Rewards Points: 502
Glazed ceramic tile doesn't require sealing.
Just get the unsanded grout sealer.
JetSwet is offline   Reply With Quote
Old 05-20-2012, 11:23 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 290
Just in case the store is out of unsanded grout sealer, I recommend a good quality penetrating sealer. Penetrating sealers look like water and do not change the appearance of the tile or grout.
Gloss sealers are sometimes used on pavers and quarry tiles if a gloss is desired. It's like an acrylic wax which will have to be re applied often. I don't recommend it even on unglazed and definitely not for you.
Use the same sealer on the counter if it's food-safe and says it can be used on food preparation areas. You might have to drop a dime for learn that.
Jaz
Tags
sealant
white grout turned dark after sealant applied mamie Tiling, ceramics, marble 1 04-11-2012 12:48 PM
Can bad grout job be salvaged? wlsmith Tiling, ceramics, marble 22 11-14-2010 07:31 AM
Shower grout discoloration Teebadoe Kitchen & Bath Remodeling 2 11-03-2010 08:07 PM
Removing grout from top of ceramic tiles markdrum1 Tiling, ceramics, marble 3 09-28-2010 10:38 AM
Tinting/re-coloring grout proofer Flooring 7 02-02-2008 11:59 PM
