-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   To seal travertine or not (http://www.diychatroom.com/f84/seal-travertine-not-40499/)
rwith 03-17-2009 12:44 AM
We have new travertine in the kitchen where it will get a moderate level of use. The installer advises not sealing it because it is not a complete protection, needs re-sealing from time to time and sealing makes it harder to re-do the grout and buff the tiles later on if needed. He thinks we should leave it unsealed and simply have someone re-buff the tiles after some years of use as needed. Does this make sense? We always thought sealing Travertine is a must, but if re-buffing and re-grouting is straightforward then maybe not.
Bob Mariani 03-17-2009 05:18 AM
it should be sealed. His reasons make no sense.
ccarlisle 03-17-2009 07:08 AM
Oh boy...where to start? First, there are no strict rules about "sealing stone" - in fact, it's much like the fashion world - where there are few rules and everybody has on opinion. So saying 'travertine must be sealed' is really over-simplifying a question that has as many answers as it has questions. It may be an easy "yes" but not a slam-dunk in my mind...:no:
Second, know that with what we have from you so far, we can't give you an answer from 'here' - because we are not 'there' - we can't see what you've got and you haven't told us.
I can't even say for sure you're talking about your floor...? are you? I guess you are - but I've seen travertine countertops so the question is valid...then what finish do you already have on it? is it highly polished (like a mirror), or honed, like a satin pillow? can you see all the little holes in the stone, from pinhead sized to about the size of a pencil eraser? are they filled with something or not? See, I can make an assumption here but you know what they say about assumptions, don't you?
Most likely it is 'filled' (it wouldn't be sanitary in a kitchen unfilled)...and 'honed'. But then again, I am assuming your supplier was either a local tile store, or a big box store and that you live in an average house, not a $3 million-mansion...so you paid around $4-6 per sq ft?
OK once we've established what you have, we then ask what you want to do. You say you want to "seal it"...from what exactly? water? from dirt? from red wine stains? from scratches made by the dog? are you thinking a natural look or a topical sealer...something like putting a wax down on a wood floor? You mention "moderate traffic"... what? 2-adults-in-slippers or four-teenagers-and-two-dogs traffic? I'll assume a bit of both.
Your guy should have tested your travertine for absorption of liquids first and then given you his thoughts on sealing it. He is right in saying it is not complete sealing and that it will need to be resealed from time to time, but he is specifically referring to a topical sealer when he mentions grout and re-buffing. Perhaps he is unsure about what type of sealer you want? does he suggest an impregnator-sealer? which one? water-based or solvent-based? How many coats? how long between coats, if more than one...how does it work and what is it going to give you - and what is his liability in all that, if something happens...will he have to solve the problems? Is he capable?
So perhaps there was some "fluff" there, when harder answers should have been given. Maybe he's a tile setter and not a stone restoration expert, so he doesn't know...not his fault entirely. So maybe he wasn't the guy to ask...
But to leave travertine as is and re-hone it every couple of years is possible - but not as easy as buffing a waxed floor with a low-speed buffer. Guys that re-hone have specialized equipment and it's a process very similar to sanding a piece of rough wood to get a table-top.
I don't want to go on, already enough to think about as it is - but these are some of the areas that need addressing if we are to answer to your satisfaction the question you raise. If nothing else, I hope you see the size of the question. But, if I assume you have filled, honed, absorbent travertine on a kitchen floor, with a moderate family and that you are looking for peace of mind and having told you that re-honing is something you might have to look at every few years, then I'd say seal it.
Now that process may take you a few days, depending on the stone and the sealer... :whistling2:
rwith 03-17-2009 12:51 PM
Toseal travertine or not
Carlisle: I appreciate your feed back.
1. It is on the floor only of a 13 x 14ft kitchen. Usage is by two adults, no pets, open to dirt from the back door plus my wife cooks a lot. It is also used as a casual social area (eating and sitting with friends around the kitchen table). We will have mats in front of the sink and stove. Modest house - no mansion here!
2. Your assumption is correct - the travertine is honed and filled. It is from Turkey and cost us $2.50 but would be $5 in the local stores.
3. The sealer I had in mind is Stonetech professional (a Dupont product) and is water based. It states "advanced microbond protection", cures in 24 hours (8 for light foot traffic) and that is about it. We prefer the natural look so if this is a topical sealer, it doesn't sound right from your comments. My natural inkling would be to apply 2 coats the first time round.
4. I will take your suggestion and do a liquids test on a spare tile as I am not in a hurry to seal it. Tea, dirt and food are the most prevalent issues.
Let me know if you have anything to add given the additional information,
Thanks again, Roger
ccarlisle 03-17-2009 03:41 PM
That's what I thought...good!
Stonetech has some very good products and I would not hestiate to use them, but no matter what sealer you put down you are going to have to be careful about dirt and sand brought in through the door (use mats inside and/or outside) and acid etching.
Orange juice, coffee, coke, any acidic product - even wine or water - will leave an etch mark on the travertine if not cleaned up right away. No product will save you from etching although some will mitigate it.
Furthermore, you should only use stone-specifc cleaners to clean the floor with not just any old cleaner. A neutral stone cleaner is all you should have under the kitchen sink.
Every few years you may need someone to come in and re-hone it; stone professionals do this regularly. Costs about as much as the tile does... FYI
mikediablo 12-06-2012 02:21 PM
Renewing an old thread.. :whistling2:
I am having a heck of a time finding a sealer that does what I want, is available in Canada, doesn't need a re-application avery 6 months and fits my budget.
I have a new tumbled travertine installation in my bathub/shower area as well as in the bathroom floor. This is the main bathroom; 2 adults, 3 kids, only bare feet or socks, no pets.
Could someone provide me with some professional insight into a good sealer?
I am looking for a natural look enhancer / sealer. Here are a couple of buzz-names I have come accross on the internet:
- Aqua Mix Enrich 'N' Seal
- Stonetech Bulletproof (would prefer the Professional Enhancer Pro Sealer, I think)
- Saniten Color Enhancer Sealer - NANOTECH
Please help! :thumbup:
JazMan 12-09-2012 12:56 PM
Mike,
If you want a natural look, (in other words the way it looks out of the box), be sure to use a penetrating sealer, not an enhancer. Don't buy a cheapo one and apply several thin coats.
Keep an eye on the shower's lower walls and floor especially well. Your tile selection requires lots of maintenance. I've yet to see one that looks great after a few years.
Jaz
joecaption 12-09-2012 01:05 PM
Very soft and poris, poor choise for a bathroom.
peggyewing 09-08-2015 04:06 PM
To seal or not to seal Travertine tile and if so when??
Hi guys, I'm very new at this so please bear with me. My husband and I just put up 40 sq. ft. of tumbled travertine backsplash in our kitchen, 3 X 6 in a subway style. I have heard so many opinions about sealing before grouting , after grouting. Ahhhh..I'm confused. Please help.
JazMan 09-08-2015 07:20 PM
Peggy,
There is no reason to seal tumbled travertine before grouting. Make sure you use a grout color that blends with the tiles, nothing that contrasts. Allow to dry for 2-3 days, then choose a sealer that gives the effect you want.
Penetrating Sealer will; Not change the appearance of the tiles or grout.
Stone Enhancer will; Darken and make the tiles look like they did when you wiped them with a damp sponge.
Please let me know what grout you're gonna use.
Jaz
ChiTownPro 09-10-2015 08:19 PM
Originally Posted by JazMan (Post 2452265)
Peggy,
Jaz
I can think of a few reasons. If you are going to use urethane grout I would definitely seal before grouting.
I would also seal to help aid in grout clean up.
JazMan 09-11-2015 01:11 PM
I think the main thing is to use a grout color that does not contrast the color of the stone. Even if you sealed the tiles, you could end up with "picture frame" staining from the unsealed edges. Again, the OP is grouting tumbled travertine which means there's holes that need to be filled with grout. You don't wanna seal or use a grout release with this type of stone.
Also, I don't see how urethane grouts would act any different and why even introduce a criteria that doesn't exist? Use a grout that blends and all will be ok. Seal everything later.
Jaz
ChiTownPro 09-11-2015 01:48 PM
Jaz
We are just going to have to agree to disagree. I have never had sealing the travertine prior to grouting cause the grout no to fill the holes. I have never seen it release at a later date either. Tumbled travertine is so dang dry that it will suck in the urethane and can cause rapid drying, which leads to a much more difficult clean up and haze possibilities.
I've also never seen picture framing on travertine. It usually occurs on tile that has a bit more translucent quality like marble. If picture framing were a true concern polished travertine would really be in trouble.
Just finished up a travertine slate mix shower install yesterday. Clean up was a breeze.
JazMan 09-11-2015 07:43 PM
Who said sealing would cause grout not to stick in the holes and cracks? The point is that you want the grout in there and there's no reason to pre-seal so grout will clean up easier.
Go ahead and pre-seal if you want to, isn't gonna hurt anything. I've never had an issue grouting tumbled marble/travertine and just sealing after to seal the tiles and grout.
No doubt in my mind that it cleaned up easy, but now you've introduced slate which should be sealed or better yet a grout release applied before grouting.
Jaz
ChiTownPro 09-12-2015 02:48 PM
Jaz
You are also a pro. This is a DIYer site. My advice is for them not for you.
Unless you have sealed the tile before grouting I can't see how you would know our have this strong of an opinion. You dint know easy unless you have sealed it first.
Slate, Travertine Marble...it helps with any natural stone.
Sent from my SM-N910V using Tapatalk
