Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 10-09-2011, 03:37 PM   #1
River rock tile on brick surface...
I'm a newbie so go easy. I'm hoping to install some pebble river rock tile (stones are stuck to mesh)on a brick ledge (outdoor kitchen). Thinking it won't be too difficult but want to avoid pitfalls.
At any rate. Wondering how to prepare the surface, which thinset ( I'm planning on using gray so the edges blend better with the mortar that's currently there), and what kind of grout.
Finally, the stone will be natural (not polished) - do I need to seal before I grout? What it the sealant runs down the side of the stone, will it keep the grout from 'sticking'?
Thanks in advance.
Steve
Savela is offline   Reply With Quote
Old 10-09-2011, 04:54 PM   #2
Tileguy
Bud Cline's Avatar
The stones won't take a sealer.
Using them out-doors requires a quality thinset mortar. I would use an unmodified thinset but add my own additive. This will make for a better thinset and a more tolerant thinset when it comes to outdoor use and weathering.
Once grouted the grout can then be sealed.
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Tile over brick handifoot Remodeling 2 01-19-2011 11:35 AM
Started Exposed Brick Wall, Studs within brick, should I stop? perry167 Building & Construction 4 01-05-2011 10:41 AM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 10:07 PM
Putting Tile over brick fireplace? sammyjk1 General Discussion 1 02-25-2008 04:47 AM
