Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 11-24-2012, 03:13 PM   #1
Retiling kitchen floor
I put down porcelain tile 10 years ago. Just had to tear up a 5x5 area due to refrigerator leaking. Saved most of the tiles. Had to replace floor. When we built house 38 years ago we put down 3 subfloors. Between floor over the joist and the next floor we placed tar paper. Next layer was 5/8 plywood then covered with 1/4 in particle board. Had to replace top 2 layers. Now the problem. Old tile still has old mortar on it. How do I remove or do I try to lay tile with old mortar. Have tried removing it with no luck. Has to be used cause tiles are now out of stock. Please help
townbuilder is offline   Reply With Quote
Old 11-24-2012, 03:43 PM   #2
Super Moderator
Either use a 4 1/2" angle grinder with a diamond cup---or leave out the top 1/4" layer of particle board and set the tile,old thinset and all, into a thick bed of modified thinset----
That particle board layer was not a good idea anyway --it falls apart when it gets wet.
Old 11-24-2012, 05:31 PM   #3
That 1/4 can be made up with 1/4 tile board.
No form of partacal board should ever be used as a subfloor or underlaymant.
Old 02-12-2013, 10:50 PM   #4
try resin fiber sanding discs, find them at HF. they have worked for me in the past. good luck
Rico_44 is offline   Reply With Quote
kitchen floor advice Grumpy Flooring 4 03-21-2011 05:34 AM
Sagging floor in kitchen...Advise please MGK01 Flooring 3 02-25-2011 01:34 PM
Rookie DIY'er: Kitchen Floor Project Gpike Flooring 2 02-25-2011 01:30 PM
How can I know if my kitchen sheet vinyl floor has an asbestos problem? hackwriter Flooring 4 01-23-2011 03:35 PM
