Replacing Tiles Over Old Thick Mortar Bed - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-27-2013, 08:43 PM   #1
Replacing tiles over old thick mortar bed
Hi everyone,
My kitchen tile is installed over what looks like a ~1" thick mortar bed (it's pretty old). The original owners installed this floor after they installed the counters, and among other things tiled in the dishwasher. When we recently had to replace the dishwasher, the only way to get it out was to chisel out a row of tile and a decent part of the mortar bed. I have since removed all of the mortar in the area and installed new wire mesh over the floor, and would like to fill in with mortar and tile in some replacement porcelain tile.
My question is this. What is the best way and products to accomplish this? Originally I thought I would mix some dry mortar, build it up to about the right level, then let it cure. After that I would add tile with normal thin set. Is this the right thing to do? I'm concerned that it will be hard to maintain the proper level if I do it that way. Is there a product I can use to fill in the ~1" deep by 49"x17" hole directly, setting tile on it while still wet so I can be sure to get the level just right?
Sorry if this is a stupid question. I'm a complete rookie on tiling and don't really know anything about different types of mortars.
Thanks!
brums22 is offline   Reply With Quote
Old 05-28-2013, 06:04 AM   #2
DIY staff
Rewards Points: 7,174
You have a thick Jersey Mud Set----
You have two choices---first---two layers of 1/2" durrock,set in a bed of thinset and nailed with roofing nails.
Second--mix a small batch of deck mud---pack that in until level--then set your tiles using a modified thinset.
Here is a link with deck mud---you can use masons mortar---How to build a shower - Building a shower pan with pre-sloped mortar bed, liner and curb.
brums22 (05-29-2013)
Old 05-28-2013, 07:37 PM   #3
Pro
JetSwet's Avatar
Rewards Points: 502
You have the wire there already. Imo the deck mud mixed to a damp consistency and packed down tight. Let dry then tile section would be the way to go although I never heard of doubling 1/2" cement board with thinset sandwiches does sounds clever to skip all that.
JetSwet is offline   Reply With Quote
The Following User Says Thank You to JetSwet For This Useful Post:
Old 05-29-2013, 07:00 PM   #4
Thanks oh'mike and JetSwet for your helpful replies. I think I will rebuild the Jersey Mud Set. Any hints on making sure the final tiles are level? I'm assuming I can just be really cautious in not building the Jersey Mud Set to high, let it cure, then use the height of the thinset adjust to get the tile height correct?
Thanks again.
Old 05-29-2013, 07:46 PM   #5
DIY staff
You have it figured out---you can easily fill a low spot---it the mud bed is to high? Big pain.
brums22 (05-30-2013)
Tags
mortar bed , tile repair
mortar question for Travertine and Granite tiles. Abs777 Tiling, ceramics, marble 6 06-10-2011 10:28 AM
How Do I Remove Mortar From Porcelain Tiles? C_J_GO Flooring 5 09-06-2009 11:42 AM
Replacing A Few Tiles On Shower Wall EDENO Remodeling 1 12-11-2006 12:25 PM
Replacing damaged shower wall tiles kevind Flooring 4 11-20-2006 01:18 PM
Replacing damaged shower wall tiles kevind Remodeling 3 11-15-2006 11:36 PM
