Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 11-29-2009, 11:08 AM   #1
Replacing Countertop Tile
I'm replacing some old tile on a bathroom countertop with granite tile. When I removed the old tile, I found blue foam underneath. Should I remove this and place a backerboard in its place or could the new tile be placed over the foam with thin-set mortar?
Thanks!
td4830 is offline   Reply With Quote
Old 11-30-2009, 08:04 PM   #2
Tile / Stone Contractor
TileArt's Avatar
Not sure what you are referring to when you say 'blue foam'? No product I can think of would be described as blue foam when removed.
That said, the better option is always to remove all signs of an old installation and rebuild from the bottom up. I would not install anything over a substrate that is unidentified. Especially not granite.
Ideally you want two 3/4" plywood layers with your substrate on top of those. This minimizes flex and solidifies your installation. Depending on the size of your countertop you can probably get away with a bit less than that.
You can use backerboard for your substrate and it will work just fine. I prefer using Schluter Ditra membrane in place of backerboard. It has better uncoupling properties and all kinds of other technical mumbo jumbo you don't care about. Let's just say it's a better option but backerboard will work fine.
TileArt is offline   Reply With Quote
Old 11-30-2009, 11:46 PM   #3
Thanks very much for your excellent answer--it is much appreciated. For your internet site, it looks like you've done some exceptional projects!
Marble Tile Countertop? Sportbilly Remodeling 16 12-09-2012 04:29 PM
Replacing Tile Floor in Shower banglenot Flooring 9 05-23-2011 10:05 PM
Removing old 6" Tile and Replacing with 6" tile Mikey_B Tiling, ceramics, marble 1 07-09-2009 10:01 PM
Replacing kitchen countertop tile budget consciou Remodeling 5 03-17-2009 10:24 AM
Replacing tile with laminate - Bad idea? Regina Phalange Flooring 6 11-22-2008 07:12 PM
