Replacement Porcelain Pavers Tile - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 06-28-2010, 11:35 PM   #1
Replacement Porcelain Pavers tile
My landlord will not refund my security deposit because I cracked a few tiles. All she can tell me is they are Porcelain Pavers and they were put in 5 years ago in Chicago. Looking online that description tells me NOTHING. I don't think 7 tiles should cost $470. Here is a link to a picture of the tiles. I can upload more if need be. I am quite desperate to get back as much as possible. She is also charging me to replace carpet in a 7x12ft room for $400. All together she will be keeping $870 for 7 tiles and carpet. Any leads will be appreciated!
http://i860.photobucket.com/albums/a...le/cats028.jpg
poohbare96 is offline   Reply With Quote
Old 06-28-2010, 11:50 PM   #2
Rewards Points: 150
Unless she kept extra tiles when they were placed 5 years ago, it'll be almost impossible to match the existing tiles. This means she might have to replace the entire area.
Honestly, $470 to replace 7 tiles doesn't sound that bad. You have to remove the grout around those 7 tiles...break out the 7 without damaging the other tiles...remove the old thinset...mix new thinset...place the tiles...then try to match the dirty grout.
Now after you've done all that, go around and clean up all the dust you created from removing the old tile, because it's going to be covering everything.
If it's my rent house, I wouldn't allow a renter to try to fix it themselves. If they did, they would lose their entire security deposit.
ConstantChange is offline   Reply With Quote
Old 06-29-2010, 05:14 PM   #3
Chicago, IL
Michael Thomas's Avatar
How did "you" crack the tiles - unless they were abused by dropping something on them, etc., cracked tiles are usually the result of incorrect installation.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
porcelain tile on linoleum jayc Flooring 3 06-01-2010 07:12 PM
Fitting a replacement floor tile applemac01 Tiling, ceramics, marble 7 03-04-2010 07:44 AM
Best tool to drill holes in Porcelain tile theedudenator Tiling, ceramics, marble 6 12-09-2009 06:44 PM
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 12:05 PM
Porcelain Tile over Linoleum hsmithfarms Flooring 9 08-12-2008 08:06 AM
