Replacement Ceramic Corner Shelf - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 10-17-2012, 11:54 PM   #1
Replacement ceramic corner shelf
I am in the process of replacing a lug back ceramic corner shelf. I have removed and cleaned the opening in the tile.
When I test fit the new replacement dish, I can see the shower walls are not square. One side of the dish fits great, but as the attached picture shows, there is a large gap on the opposite side, especially at the corner.
I am looking for ideas for attaching with such a large gap. My plan is to use thin set, but I have doubts about filling such a large gap with thin set.
I appreciate any suggestions!
shucky ducky is offline   Reply With Quote
Old 10-18-2012, 04:35 AM   #2
DIY staff
Rewards Points: 7,174
Your best adhesive for that is 100% silicone caulk----not thinset---tape for a couple of days before you trust it--silicone that deep will take a while to set up---
shucky ducky (10-18-2012)
Old 10-18-2012, 01:16 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 388
Ducky,
I'd prefer to use thinset, but silicone will work too. I guess cuz I'd be more likely to have thinset handy and ready. I'd only use silicone if installing it was an after-thought using a flat-back fixture direct on the tiles.
You should split the difference with the poor fit. You could also cut some of the back of the corner dish to make it work better if you had a wet saw handy.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
Old 10-18-2012, 03:27 PM   #4
Many thanks guy. Great ideas! So glad I joined.
Retrofit ceramic tile corner shelf in shower jgibbs Tiling, ceramics, marble 4 06-07-2012 11:29 AM
Paper Faced Metal Corner Bead & Multiple Intersecting Corners Fire4Effect Drywall & Plaster 2 04-09-2012 09:53 PM
Built-in Corner Shelf Unit VikingDinKC Carpentry 3 02-13-2012 06:21 PM
crown molding fitting problem momof2labs Carpentry 16 10-15-2011 12:45 PM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 10:16 PM
