Replace Broken Tile - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-10-2010, 06:16 PM   #1
Replace broken tile
I had to break out a tile to fix a water leak in my shower. the wall has a cement backerboard behind the broken tile which was removed leaving a 6" square. (the copper pipe had a pinhole i think from freezing since it is in an outseide wall)
Can I fill the hole with 3/4" plywood and then put a new tile over it?
Thanks for any help
jergens is offline   Reply With Quote
Old 05-10-2010, 06:49 PM   #2
better with cement board
The older I get the better I was
How to make wall smooth after removing tile? cheapchick Remodeling 20 04-09-2012 01:59 PM
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 06:08 PM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 07:06 PM
basement issues - tile, mastic, moisture pfisch Flooring 6 12-01-2008 01:35 PM
