Repair Durock Imperfections Before Tiling - Tiling, ceramics, marble - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-06-2011, 01:19 PM   #31
another question
I'm on to the bathroom floor -- it's very small, about 3' X 5'. There is 1 X 6 slanted subfloor, and I've put 3/4 ply on top of that. I read that Durock is recommended on top of that, but I can't afford more height (HD only carries 1/2 inch).
l was thinking of Redguarding the plywood prior to tiling. Would that work? Or would any water just sit on that and degrade the thinset somehow?
Any other suggestions on how to get that ready for tile without adding height?
Using 1 inch hex.
thanks again! Taran
Taran7 is offline   Reply With Quote
Old 08-07-2011, 03:32 PM   #32
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Water won't be "degrading" thinset, why would it? Thinset is the tile adhesive of choice in all applications, why would water now and suddenly degrade the thinset on your floor?
There are all brands of tilebacker available in 1/4" thickness, it doesn't have to be Durock. Quarter inch tilebacker boards are everywhere.
Home Depot also sells Schluter DITRA, a plastic tilebacker that is only 1/8" thick.
When installing tile in a proper fashion we can't always 100% of the time have what we want as it relates to floor height. Had you not used 3/4" ply and used something a little thinner you would have room for more tilebacker height.
XXX
Old 08-07-2011, 04:59 PM   #33
ok thanks again, I'm looking for the Ditra -- HD here in CA does not carry it... Taran
Old 08-17-2011, 02:04 AM   #34
Bud- I just learned that the Ditra minimum tile is 2" X 2". My tile is 1" X 1". It's such a small floor, could I get away with a triple coat of Redguard instead?
The tile I took up was put right on top of thinner plywood than I'm using, nothing in between, and it failed but only after like 30 years...
thanks, Taran
Old 08-17-2011, 04:49 PM   #35
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Using Redgard "instead" of DITRA isn't the same thing...Redgard in no way replaces DITRA but I see what you are saying. I suppose you could probably do that.
XXX
Old 08-17-2011, 04:55 PM   #36
I wised up and found some 1/4 inch Hardie board at a better Home Depot and will go with that... thanks again, Taran
The Following User Says Thank You to Taran7 For This Useful Post:
Bud Cline (08-17-2011)
Tags
durock , mortar , shower , thinset , tile
repair tiling and tub surround Commops106 Building & Construction 0 04-05-2011 08:11 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
replacing tile on durock, how to repair part of durock board already on floor? gared@roadrunne Tiling, ceramics, marble 1 01-15-2011 06:01 PM
Repair Compounds saggdevil Painting 3 04-25-2010 04:02 PM
is this bad tiling or am I being fusy??? rodger_j Flooring 23 07-16-2008 04:44 PM
