Rent Tile Cutter Or Buy Cheap One? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-14-2009, 01:05 AM   #1
Rewards Points: 81
Rent tile cutter or buy cheap one?
It looks like I can rent a good tile cutter for about $40, or I can buy one from Lowes/Home Depot for about $88 -- a Workforce one. I'm tiling a tub surround, and probably other projects of a similar size down the roads. I feel like if the Workforce one will do a sufficient job I'd rather go that route, but if it'll drive me nuts, then I'd rather rent. What's the recommended route?
Thanks!
99miles is offline   Reply With Quote
Old 08-14-2009, 01:35 AM   #2
Renovation Contractor
Paragon's Avatar
Rewards Points: 150
straight short cuts workforce is great for a small job or two. If you can rent one and get the stuff cut in a day you can save even more. Angle cuts? You WILL get frustrated with the WF saw. You might even be able to purchase a little higher quality saw use it and resell it for almost what you paid for it but in todays economy with so many going out of business you may not. I make money with my tools so I invest in what I purchase but some don't care. Not sure if any of this helps or not but is just my .02
Good luck be safe!
James D. Van Raden
Owner, Paragon Renovations Moorhead, MN/ Fargo, ND
"Committed to providing the finest renovation services available"
Paragon is offline   Reply With Quote
Old 08-14-2009, 03:15 AM   #3
Oldguy
Rehabber's Avatar
I own 2 tile saws, an MK101 and a chep saw similar to the WF you are looking at. For small jobs I use the small saw. It is light, easily transportable and does most jobs well. Not nearly as fast as the MK101 though.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 08-14-2009, 07:13 AM   #4
I have one of the small saws too - on sale about $50
I'm on my second blade
It does OK, I'd rather have a bigger saw with the tiling jobs I've done
I haven't had to do any angle cuts really
Once the blade wears out it will start to chatter/move as you try to push the tile thru
That's how you will know the blade has worn out
Old 08-15-2009, 06:34 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Buy a saw. It will take the urgency to get finished out of the mix.
Try your local Craig's list.
XXX
