Removing White (calcium Deposits?) From Pool Tile? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-13-2010, 03:42 PM   #1
Removing white (calcium deposits?) from pool tile?
Hello, hope i posted this in the right section. Have an old pool and am cleaning it, there is a white residue on the tiles that is very difficult to get off w/o ruining the tiles. Can anyone help me with an appropriate way,or chemical, or tool that would help? Thank you for your time!
rsclark67 is offline   Reply With Quote
Old 05-13-2010, 04:19 PM   #2
Rewards Points: 152
If it's calcium, vinegar should remove it. I suspect it isn't. Try a little vinegar though, in a small unobtrusive area, just in case. Is it outdoors? If not, be sure you have good ventilation, in case it's residue of some other chemical (pool chemicals can be nasty, although I don't know what would be so difficult to remove). If it's on the pool wall, soak a rag in vinegar & somehow get it do stay up against the residue.
Double-posting is frowned upon.
lazzlazz is offline   Reply With Quote
Old 05-13-2010, 05:00 PM   #3
It is outside, and could be pool chemicals, could be anything, will try the vinegar, thank you.And thank you for the double posting heads up. SORRY TO ALL FOR DOUBLE POSTING-DIDN'T KNOW.
Old 05-15-2010, 05:15 AM   #4
zep makes a calcium and lime remover that actually does a pretty decent job. the stuff is just toxic to breathe but i've had success in well water stained toilets and mineral build up elsewhere.
racebum is offline   Reply With Quote
Old 05-15-2010, 07:09 AM   #5
DIY staff
Rewards Points: 7,174
If the milder acids don't work for you try "The Works" toilet bowl cleaner--The cheap watery kind--Not the new 'improved' thicker stuff.
Apply--scrub clean--rinse well---nasty fumes--will damage grout if not rinsed-promptly.--Mike---
Old 05-15-2010, 09:39 AM   #6
Thank you for your answers, will keep trying them
Removing Bathroom Ceramic Tile Laid in 1970 mark2741 Flooring 6 12-08-2011 08:55 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
removing old paint from tile dbldee20 Painting 5 01-17-2009 02:37 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
How to remove white deposits on grout? digexpressions Flooring 6 05-12-2008 09:13 PM
