Removing Tile For Reuse - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 07-27-2012, 02:02 AM   #1
BabsHoney's Avatar
Rewards Points: 150
Removing tile for reuse
I think I may have stumbled into some luck!
My relatives are buying a very old house and will need to redo the kitchen. The small green tiles that are currently serving as a counter top, while absolutely hideous in this kitchen, are exactly what I want as my accent tiles in the kitchen and bathroom. Since they are pulling it all out, I get to keep it! Yay!
But... will it be usable? Are there any tips/tricks to removing it so that I can use it? I don't need much so it's not a huge deal if we can't salvage any of it but free is best right?
BabsHoney is offline   Reply With Quote
Old 07-27-2012, 07:04 AM   #2
Rewards Points: 14,026
All depends on how poorly it was installed.
If it was done right there's about a 0% chance of saving it.
I'd be looking for some new tiles.
Check on Craigs List, or a Restore for some cheap tile.
Old 07-27-2012, 07:09 AM   #3
DIY staff
Rewards Points: 7,174
You may need a table belt sander---unless the tile is something really special the cost in sandpaper,tools,chemicals and time make salvaged tiles very expensive---
Old 07-27-2012, 11:20 AM   #4
BabsHoney's Avatar
Rewards Points: 150
Well I was a little afraid of that. I figured I could still try. If they are usable great; if not, then at least I tried.
How do I go about getting off the residual junk on the tiles though? I figured some sanding, but there are chemicals as well?
Old 07-27-2012, 11:41 AM   #5
DIY staff
Depends on the composition of the tile---chemicals can be used on porcelain tile---but will soak into soft bisque backed tiles and cause bonding failures ---so sanding is your safest method.
BabsHoney (07-27-2012)
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 08:03 PM
How to make wall smooth after removing tile? cheapchick Remodeling 20 04-09-2012 01:59 PM
Removing Tile Over Hardwood: Need Help With Kitchen/Bath Creelove Flooring 3 02-01-2011 06:03 AM
Removing peel and stick tile adhesive in preparation for tile stubborn1 Flooring 3 01-09-2011 01:34 PM
Removing floor tile glue from a wood floor mrmordun Flooring 2 09-03-2008 09:41 PM
