Removing Tile From A Radiant Heat Flooring... - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-02-2013, 11:41 AM   #1
Removing tile from a radiant heat flooring...
Need some advice on the best way to do this friends...let me hear from you.
Hopefully some of you have done it and know the proven way to get it done right.
Mahalo...George
thesquyres@yahoo.com
thesquyres is offline   Reply With Quote
Old 05-02-2013, 08:41 PM   #2
DIY staff
Rewards Points: 7,174
How was the installation done? If the heat is embedded in self leveling compound you might be able to smash the tiles without damage---might--
If it's thinset and tile directly over a mat---you will be unlikely to save that---What are you doing?
Old 05-02-2013, 08:46 PM   #3
Rewards Points: 6,652
Suggest that if you are tearing up the floor, to just trash everything, and install all new mat and underlayment backer under the tile.
Old 05-10-2013, 06:10 PM   #4
Remodeling Contractor
I'm with Mike on this one. Was SLU used in the original installation?
Here's a video showing a tile I needed to change with floor heat, only difference is that I was the one that installed the floor heat and KNEW that it was protected because I used SLU.
Phil,
http://www.edgestripkits.com
pgc555 is offline   Reply With Quote
How to make wall smooth after removing tile? cheapchick Remodeling 20 04-09-2012 01:59 PM
Removing Bathroom Ceramic Tile Laid in 1970 mark2741 Flooring 6 12-08-2011 08:55 AM
Renovation tile over radiant heat loncoleman Flooring 6 09-26-2011 10:53 AM
Another Knucklehead Considers Laying Tile Over Vinyl Flooring tacklingherlist Flooring 14 08-26-2011 11:13 PM
removing flooring, going with tile jwinters03 Tiling, ceramics, marble 12 08-22-2011 11:43 AM
