Removing Tile - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 12-31-2014, 06:15 AM   #1
Rewards Points: 862
Removing tile
How big of a job is it to remove old tile with the intent to replace it with laminate flooring?
I knows its hard to remove old vinyl. How would you compare removing vinyl to tile?
Startingover is online now   Reply With Quote
Old 12-31-2014, 06:21 AM   #2
DIY staff
Rewards Points: 3,998
Removing tile
Ceramic tile? The difficulty depends on how it was installed---is it over concrete?
Wood floor?
If you are not sure, remove a floor heat register,if you have one---
Laminate can be installed on top of ceramic tile---
oh'mike is online now   Reply With Quote
Startingover (12-31-2014)
Old 12-31-2014, 07:53 AM   #3
Rewards Points: 862
Removing tile
It would be over a concrete slab. Wouldn't that raise it to where people would catch their toe if the laminate was on top on ceramic tile?
Old 12-31-2014, 08:00 AM   #4
DIY staff
Removing tile
That can be a problem---if removal is done---it is a messy and labor intensive job--
some tile will smash and pop right off when struck with a heavy hammer---leaving behind only the thinset (cement adhesive)
On larger jobs of for tiles that are stuck really well--a chipping hammer is often used--these are an electric hammer drill with a steel chisel--they can be rented--the machines are rather expensive to buy--Bosch 'bull dog' is a popular brand--google images will show you what it looks like---
Wear leather gloves and goggles---lots of chips go flying---dusty mess---
Old 12-31-2014, 12:21 PM   #5
Rewards Points: 862
Removing tile
UGH.......I was afraid that would be the anwser.
The Following User Says Thank You to Startingover For This Useful Post:
oh'mike (12-31-2014)
Old 12-31-2014, 08:13 PM   #6
DIY staff
Removing tile
Some jobs are just plane old hard work---made somewhat easier by modern power tools---that one is messy,hard work.
Startingover (01-01-2015)
Old 01-02-2015, 09:59 PM   #7
Rewards Points: 99
Removing tile
why is it necessary to remove the tile? A transition strip would go in at any change of flooring regardless of if there was tile under the laminate or not.
olzo55 is offline   Reply With Quote
removing 1 ceramic tile without damage? jaes Flooring 3 03-24-2013 10:08 PM
Removing tile (or not) over vinylay flooring Rusty69 Flooring 2 03-19-2013 11:32 PM
How to make wall smooth after removing tile? cheapchick Remodeling 20 04-09-2012 02:59 PM
Removing Tile Over Hardwood: Need Help With Kitchen/Bath Creelove Flooring 3 02-01-2011 07:03 AM
Removing vinyl tile (at least I think it's some sort of vinyl) natecase13 Flooring 1 07-13-2010 11:55 AM
