Removing Thinset From Tile . - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 11-09-2011, 05:36 PM   #1
DJT
Removing Thinset from tile .
I'd like to reuse 25 year old tile that's beginning to become loose - it's no longer available so I cannot buy new pieces. Any ideas on how to remove thinset from tile so that they can be re-laid?
DJT is offline   Reply With Quote
Old 11-14-2011, 06:49 PM   #2
If you can get it ip wo breaking you can use 40 grit paper to remove the thinset
dvatt is offline   Reply With Quote
Old 11-26-2011, 08:46 AM   #3
RayVan
I recently used my Bosch oscillationg tool with a triangular carbide rasp to remove thinset from the back of ceramic tiles and from the plywood substrate. This woked very well and was fast too and made relaying the ties very easy.
RayVan997 is offline   Reply With Quote
Old 11-26-2011, 10:16 AM   #4
Was there a lot of dust in the air or did it just lay on the floor?
Old 11-26-2011, 10:29 AM   #5
RayVan
Not really too much dust. The particular Bosch tool I used is battery-operated and does not have a very powerful cooling fan, but an AC-operated tool might kick up more dust. I did, however, keep my wife's Hoover near at hand and I vacuumed up the dust frequently.
Removing Bathroom Ceramic Tile Laid in 1970 mark2741 Flooring 6 12-08-2011 09:55 AM
Tile / modified thinset misguydead Building & Construction 4 09-28-2011 11:34 AM
Removing Thinset from Badly Installed Tile bobbygarafolo Tiling, ceramics, marble 2 04-21-2010 02:29 PM
Mixing Mastic and Thinset in a Tile Job smata67 Building & Construction 2 08-09-2009 11:38 PM
Removing Ceramic Tile csnolan General DIY Discussions 1 10-26-2007 11:37 PM
