Removing Liquid Nails From Brick Fireplace. - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 01-20-2012, 09:47 AM   #1
Removing liquid nails from brick fireplace.
I have a used brick fireplace and the previous owner attached a rubber edge piece to the hearth (gray and very ugly). Several of the pieces have come off and left behind what appears to be liquid nails. Is there a way to remove the liquid nails from the bricks without harming the brick?
chrisacz is offline   Reply With Quote
Old 01-20-2012, 09:54 AM   #2
mike owes me $53 dollars
Tech Dawg's Avatar
A utility knife, sharp chisel, steady hand w/ a lot of patience
Perhaps a caulk remover spray might help loosen it up...
Todd
www.aloneeagle.com
Tech Dawg is offline   Reply With Quote
Old 01-20-2012, 10:50 AM   #3
Used bricks are soft. Scrape the caulk off the best you can and try scratch the brick as little as possible then take some sooty dirt and rub into the scratch areas and it will likely hide the scratch marks.
Michael Olding is offline   Reply With Quote
Old 01-20-2012, 11:13 AM   #4
DIY staff
Rewards Points: 7,174
Paint remover will soften the old adhesive after you scrape off as much as you can---wash thoroughly --
Remove Brick Fireplace Clemsig07 Building & Construction 1 04-12-2011 08:59 PM
Removing paint from fireplace brick dwoloz Painting 4 08-22-2010 11:16 PM
Liquid nails - which kind? DIYGST Building & Construction 10 11-26-2008 04:50 PM
LAMINATE: liquid nails nathan.tran Flooring 3 07-28-2008 05:33 PM
Removing a Fireplace - suggestions? BigFloyd Building & Construction 1 08-03-2006 05:01 PM
