Removing Flooring, Going With Tile - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-14-2011, 02:30 PM   #1
removing flooring, going with tile
house built in 1958, replaced the main flooring because after I pulled up the plywood subfloor to expose the 1x6s laying diagonal I fell through a couple of spots.....FUN
anywho, Previous home owner carpeted over the hardwood in the home, and over the transition area of hardwood to the vinyl flooring in the kitchen. I know I cant lay tile directly over hardwood due to it alwas expanding and contracting, but can I do it if i screw down a 1/4" conreteboard?
jwinters03 is offline   Reply With Quote
Old 08-14-2011, 02:50 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 424
No. It has been done but it's a very high failure rate installation. It's considered HACK work.
You're supposed to remove the hardwood, (you'd want to anyway otherwise the floor gets too high). After the hardwood is gone you need to repair/replace the planks as necessary and then install min. 1/2" underlayment grade ply. If the boards are cupped or bowed you may want thicker ply. Then you can install the tile backer into fresh thin set mortar or a mating such as Ditra, then the tiles.
Jaz
JazMan is online now   Reply With Quote
Old 08-20-2011, 10:58 AM   #3
Tile with Style
BlueStoneFloors's Avatar
Yep, you will have big problems if you try to cut corners like this. Tile has no sympathy for lazy people. Have you considered pulling the carpet and refinishing the existing wood? A professional wood flooring outfit can generally make an old wood floor look really good, even if it's had carpet put over it. Best of Luck
BlueStoneFloors is offline   Reply With Quote
Old 08-20-2011, 12:50 PM   #4
no wood refinishing here. lol.
my only question is, why wouldnt it work? honestly i want to know.
if the concrete board is down and screwed into place, how would that effect the outcome of everything?
Old 08-21-2011, 09:15 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 424
Screwed down to what? It's fastened to the hardwood that is shrinking and expanding all the time.
Ever have a sticky door or drawer when the humidity is high? How about squeaks when it's dry? Ever notice the expansion finger joints on bridges?
It's you choice if you wanna do it wrong so you can save a day prepping the job right. If you were hiring someone you'd want it done right. So what the difference now?
Jaz
Old 08-21-2011, 09:35 PM   #6
For one, there's no reason to be a smartass. I simply asked for a reason why it wouldn't work. Yes I understand all about expansion andsuch with the variating temperatures and humidity. But the plywood subfloor would be doing the exact same thing. Instead of being a jackass, why don't you be informative with an answer when someone is seeking help with a logical "want to know" question.
Old 08-22-2011, 09:20 AM   #7
Tile with Style
You asked for an explanation and he broke it down for you. What's your problem dude? Did you look at the guy's profile? He's been doing tile for 30 years- he knows what he's talking about. We're not here to talk nice to you and stroke your ego. If you can't eat a little humble pie, don't ask for honest opinions.
Hell is 8 months of nothing but slate work...
Old 08-22-2011, 09:34 AM   #8
I have seen his profile. And someone with his experiance should help a little more instead of trying to come across as a jackass. I simply want to know why wouldn't the plywood be doing the same thing as the hardwood?
Old 08-22-2011, 09:40 AM   #9
Tileguy
JazMan's Avatar
Rewards Points: 424
Wow! Are you calling BlueStone a smartass for the "lazy people" reference or was that comment meant for me? I certainly didn't expect that from my rather mild mannered comment. It was good advice.
What are you biaching about? Especially for the price charged. Do we owe you something? Anyway, if the the comment was for me, I thank you very much. Better a smartass than a dumb one.
Now, you seem to know that solid wood is very unstable but do not want to believe your own words.
You said;
Wrong, no it won't, and that is why plywood was invented. Plywood is much more stable, the plies are oriented in opposite directions for that purpose. To that you add the uncoupling affect of concrete backer or a product such as Ditra, and you've got a floor that will last a lifetime.
Jaz
Old 08-22-2011, 09:56 AM   #10
yes do remove the hardwood.than think about the added weight tile will provide?the old joist are going to sag.if you lay 18x18 tile the substraight needs to be perfect,to get it that way over sheet goods will require a large notch trowel and plenty of thin set.you may need to add midspans to the joist system?
Marbledust is offline   Reply With Quote
Old 08-22-2011, 10:21 AM   #11
Tile with Style
Ok, well there's no problem wanting to know more but let's not be rude about it, M'kay? Go ahead and set tile right on the hardwood-use mastic and pre-mixed grout. Tile and grout the same day, and use unsanded grout with 1/2" grout lines.
J/K don't do any of that, tear it out, it doesn't take that long and you will have a floor to be proud of for a long time. Good Luck
Old 08-22-2011, 10:35 AM   #12
Tileguy
JazMan's Avatar
Rewards Points: 424
Too funny!
That's a likely scenario if you'd talk to some of the vested clerks at the big box stores. And they get your $$$$, while we do this to help people. Something wrong there.
Jaz
Old 08-22-2011, 11:43 AM   #13
Jaz
thats what i was looking for. thanks. simply wanted to know WHY it wouldnt work.
Removing Thinset from Badly Installed Tile bobbygarafolo Tiling, ceramics, marble 2 04-21-2010 01:29 PM
Need Advice - Removing Bath Wall Tile Soxckersfc2002 Kitchen & Bath Remodeling 6 02-01-2010 10:49 AM
Removing recently installed shower tile cm3putter Plumbing 1 12-15-2009 08:24 PM
removing glass 4x4 tile tilewoes Building & Construction 1 06-10-2008 09:54 PM
Removing Ceramic Tile csnolan General DIY Discussions 1 10-26-2007 10:37 PM
