Remove Tiles Around Sunken Bathtub - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 12-12-2008, 06:46 PM   #1
Remove tiles around sunken bathtub
Hello,
I am new to this forum and I hope that there is somebody out there that can help me.
I want to retile my master bath and have a sunken corner tub with tiles all around.
Originally the tiles were layed and the tub ledge is on top of the tiles.
What is the best way (tool?) to remove the old tiles around the tub without damagin the tub itself.
Any tips would be greatly appreciated.
Sabine
Sabine is offline   Reply With Quote
Old 12-12-2008, 07:35 PM   #2
the Musigician
DangerMouse's Avatar
someone else here may have a better answer, but i don't think it's going to be easy unless you pull the tub off the top of those tiles.
DM
Old 12-13-2008, 10:10 AM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I want to retile my master bath and have a sunken corner tub with tiles all around. Originally the tiles were layed and the tub ledge is on top of the tiles.
Remove the tub.
Old 12-15-2008, 07:29 AM   #4
i'd use a 4" grinder w/.110" dri-diamond blade & finish the corner/wall cuts w/dremel & 5in1 tool,,, obviously you need to be precise & careful,,, you should use a GOOD dustmask, safety goggles, & faceshield,,, 1 hand on the grinder & the other holding the wet/dry vac hose
yesitsconcrete is offline   Reply With Quote
How to remove thinset residue after old tiles removed? sz8 Flooring 11 01-01-2011 10:49 PM
Old ceiling tiles - remove? repaint? sertiphyible Remodeling 5 08-24-2008 11:36 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
Need some advice on how to remove ceramic tiles over wood floors. sandman512 Flooring 4 09-02-2007 12:03 PM
remove damage vinyl tiles harold938 Carpentry 2 11-16-2006 01:14 AM
