Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 09-30-2011, 08:40 PM   #1
Remove sealant from ceramic tile
The sealant was put on before the ceramic tile on my shower walls was cleaned properly and now they look dusty. How can I remove the sealant so I can clean the tile properly?
Ann Hebert is offline   Reply With Quote
Old 09-30-2011, 09:44 PM   #2
Super Moderator
What kind of grout?
Have you tried washing the tile work yet? I might simply be a bit of grout haze that will wipe right off.
What kind of tile? Tiles are not usually sealed at any time---only natural stone is sealed.--Mike---
Old 09-30-2011, 09:51 PM   #3
Thanks for answering. It was an after market sealant that was put on. We tried scrubbing it down, but it is all under the coating of sealant. Is there anything that will remove it from the ceramic tile? Thanks Ann
Old 09-30-2011, 10:03 PM   #4
Super Moderator
My post vanished---Computers--got to love them!
Try alcohol first--some times the only thing that will dissolve the sealants is more sealant.
Give us the brand of sealant--often there is a technical help line for the company---
Bud or Jaz might have an answer ,so be patient----Mike---
Ann Hebert (09-30-2011)
Old 09-30-2011, 10:35 PM   #5
Tileguy
Bud Cline's Avatar
Bud doesn't know either. Call the sealer manufacturer and see what they suggest.
Could use some help on ceramic vs duraceramic tile helpmike Flooring 17 03-29-2011 11:42 PM
Cutting ceramic tile away from bathtub Tomgrillo Tiling, ceramics, marble 2 03-24-2011 12:04 AM
Want to change ceramic tile to granite tile smart2surf Flooring 3 06-24-2009 09:11 PM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 07:12 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
