Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 08-25-2012, 05:17 PM   #1
HomeOwner
remove hardened thin set from ceramic tile
I removed several 16" ceramic tiles that were loosened from the floor by a few kitchen floods. Half the thin set remained adhered to the underside of the tiles. I am now trying to remove the thin set from the underside of the tiles so I can re-use them. How do you remove the hardened thin set without breaking the tile?
DvanDee is offline   Reply With Quote
Old 08-25-2012, 06:05 PM   #2
Super Moderator
I suggest a belt sander with 50 grit paper----support the tiles well and don't let them get hot from the sander.
An angle grinder with a diamond cup will also do---but might be to expensive for one project.
oh'mike is online now   Reply With Quote
Old 08-27-2012, 12:45 PM   #3
HomeOwner
Thanks Oh'Mike for your suggestion. Will try the 50 grit right away. I'm sure it will beat the tedious chisel-chipping (4 hours per tile).
Ceramic tile over subfloor in Kitchen pinkertonpv Flooring 11 01-12-2013 01:40 PM
Retrofit ceramic tile corner shelf in shower jgibbs Tiling, ceramics, marble 4 06-07-2012 12:29 PM
Could use some help on ceramic vs duraceramic tile helpmike Flooring 17 03-29-2011 11:42 PM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 07:12 PM
stains on ceramic tile sdgoss Flooring 4 09-19-2008 07:19 PM
