Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 08-08-2010, 05:50 PM   #1
50s homeowner
Remove embossing leveler residue from unglazed tile?
Our house was built in 1957. We recently tore up the vinyl floor in the entryway to see what was underneath with the intention to either restore what was there if it was in good enough shape, or to have the floor re-tiled.
We found the original mosaic tile floor from when the house was built, hiding under a thick layer of embossing leveler. None of the tiles were cracked or broken, or even loose.
We managed to soften and scrape up the leveler but the floor still has an annoying white residue on it that I can't seem to get rid of no matter what I do.
Here is what I have tried so far:
Diluted white vinegar
Straight white vinegar
Goof off
Lacquer thinner
Denatured alcohol
Grout haze remover
Acidic tile cleaner (contains hydrochloric acid)
Magic eraser
Buffing with dry cloth
Polishing pad attached to power sander
CLR
So far the acidic tile cleaner has been the most effective but it requires multiple applications to even see a difference and the tiles and grout are still hazy. It looks great when it's wet but once it dries, the haze returns.
Does anyone have any advice on what else I can try? Should I throw in the towel and call in a professional? If so, what type of professional...a cleaner, or a tile laying expert? Can this floor be saved? I would really like to save it; my house has a lot of its original features and surfaces and I am a big fan of the era. I would really like to keep this floor.
Thank you in advance!
retrohouse is offline   Reply With Quote
Old 08-09-2010, 12:18 AM   #2
you sat it looks good wet, try a sealer. test a small section and let it dry over night.
haversack tile is offline   Reply With Quote
Old 08-15-2010, 11:32 AM   #3
50s homeowner
Thank you for the suggestion; I tried it and it didn't work.
Old 08-15-2010, 12:56 PM   #4
Tileguy
Bud Cline's Avatar
Not a solution to your problem but an idea of what you may be dealing with.
Mosaic tiles of that vintage were likely made of porcelain ceramic. Porcelain ceramic develops microscopic pores in its surface during the firing (kiln) process. These pores then collect anything that is applied to the tile and can fit into the pores. It then becomes very difficult (maybe impossible) to remove whatever this substance is from the pores.
I would suggest trying to stain the white substance that is hanging in the pores. Can't guarantee this would work but worth a try. Select a desirable tile grout and vigorously spread it over an area. The hope is the color pigments will re-stain the white. Wipe it off with a sponge and see if the color has changed and is more desirable.
Just an idea that might work for you.
How to remove thinset residue after old tiles removed? sz8 Flooring 11 01-01-2011 10:49 PM
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 05:39 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
How do I remove this ceramic tile? tripower Flooring 5 07-23-2007 10:45 PM
Tile over, or tile under? jeffyisfive Flooring 4 01-24-2007 12:29 PM
