Removal Of Grout - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-27-2005, 10:09 AM   #1
Removal of grout
how do i remove grout out of floor tiles so i can regrout them
hugoboss is offline   Reply With Quote
Old 03-27-2005, 05:15 PM   #2
Hey
Removing grout is no fun. First of do you have to. Many times it can be cleaned the sealed and if a darker grout is wanted then it can be stained.
Well Back to you question various way to remove grout. I have seen "as on tv" diamond blades for rotatory cutters. I would believe the risk of damaging the tiles with such a unit would be eminence. I am not recommending using power tools except for a vacuum to pick up the broken up grout.
Take a medium to small nail and drive it in a scrap dowel or similar the scrap will act as a handle wile you can slowly work the grout out with the nail.(probably about a 10d go smaller or larger for your use though) If the nail bends replace it. A awl or ice pick may also work well. a small putty knife sometimes can also help. I know of no easy way but sometimes it does need to be done. Maybe other members have a quick trick way? I too would like to here of a easy way.
Mgmopar
MgMopar is offline   Reply With Quote
Old 10-20-2008, 06:17 PM   #3
we're not tile guys but we use abrasive coated tile knives avail in apron stores' tile sections,,, think they're coated w/alum oxide,,, we also use carbide tipp'd style, too.
think i'd rather use a dremel rather'n the oscillating fein tool,,, $400 ? ? ? - YIKES ! ! !
harden'd cut nails or conc nails work, too, but much slower imn-s-hfo
yes.itsconcrete is offline   Reply With Quote
Old 11-02-2008, 03:52 PM   #4
Home Imp./Remodeler
There is a grout removal kit available from Dremel. It's a bit and a router-like collar that helps guide your bit along the joints. I've used it with success many times. The bits tend to wear out quickly, though, so make sure you get a couple of extras.
Ed. to add - YIKES! I just noticed that the OP is over 3 years old. D'oh!
Dan V. is offline   Reply With Quote
Old 11-02-2008, 04:26 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
WOW!!!!!!
For about eight bucks you can buy a "grout saw" at any home center. It's labor-intensive but do-able. There are many ways that include power tools but the grout saw does the trick.
Old 11-09-2008, 03:37 AM   #6
Hope Depot got a special diamond knife grout remover.It s not fun doing that
detroitMi is offline   Reply With Quote
