Regrouting Porcelain - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 06-01-2010, 08:39 AM   #1
Just call me Andrew
Rewards Points: 1,020
Regrouting porcelain
I just had a new shower installed. The floor is made of 2x2 porcelain. The grout lines look normal, but when you step on it barefoot, you can feel the edges of the tiles, which are slightly sharp. Is it possible to regrout over the existing grout, which is epoxy, to raise the grout line more flush with the top of the tile?
Andrew
secutanudu is offline   Reply With Quote
Old 06-01-2010, 05:17 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That won't work at all.
What is under the tile?
What type of substrate was used?
XXX
Old 06-01-2010, 05:33 PM   #3
Just call me Andrew
It was installed on top of a kerdi shower system floor. It's not worth ripping up the tile, does grout not stick to cured grout?
Andrew
Old 06-01-2010, 06:23 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
But what is under the KERDI? Is it a KERDI Shower Kit, meaning a Styrofoam pre-sloping base, or was the KERDI installed over a concrete slope? It can make a difference.
In normal cases grout does not stick to cured grout (for very long). In the case of epoxy grout, it would be best to gouge the existing grout and then reapply more epoxy grout.
If you could answer the questions it would be helpful.
XXX
Old 06-01-2010, 11:00 PM   #5
Just call me Andrew
Oh, it's on top of the foam pre-sloping base. Sorry I left that out...
Andrew
Old 06-04-2010, 11:50 PM   #6
Just call me Andrew
Any ideas?
Andrew
Old 06-05-2010, 12:04 AM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Well I've seen this once before.
I used two inch porcelain tiles on a Schluter foam base. The owner/customer stands about six foot-three and weighs-in at around two hundred-sixty pounds. The grout cracked exactly where he was stepping into his shower every morning.
Any of this sound familiar to you?
If the foam hasn't compressed and the tiles aren't loose, you could dig out the broken grout and regrout, but obviously this isn't a permanent fix unless maybe you change your habits a little.
I've not heard of any issues with those Schluter Shower Kits with my one exception. I wonder if you are the second exception.
XXX
Old 06-05-2010, 12:21 AM   #8
Just call me Andrew
I am only 160 pounds :P The problem isn't cracked grout, it's that when the grout was originally installed, i just don't think enough was put in. I'd like the grout lines a little higher.
Andrew
Old 06-05-2010, 10:11 AM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Keep in mind that immediately below the tile is where the waterproofing membrane is located in this shower. Don't damage that membrane.
XXX
Old 06-05-2010, 10:17 AM   #10
Just call me Andrew
When you say gouge, do you mean remove? Or just rough up?
Andrew
Old 06-05-2010, 10:40 AM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Remove.
Remove about 2/3's deep. A heat gun will soften the grout for removal but don't over heat anything also because of the waterproof membrane just below the tile.
XXX
Old 06-05-2010, 10:48 AM   #12
Just call me Andrew
I have a feeling I'll either hire someone or get used to it.
Would a tile guy charge an arm and a leg for something like that? They are 2x2 tiles, so might be time consuming.
Andrew
Old 06-05-2010, 10:53 AM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You say this is a new shower. Why not call the installer back and have him do it right?
XXX
porcelain tiles humberguy Flooring 0 01-14-2010 05:06 PM
tile saw advice for 24" porcelain tiles diy'er on LI Tiling, ceramics, marble 12 10-11-2009 04:34 PM
Porcelain Quality on Steel and Cast Iron Tub? MrTubz General DIY Discussions 5 03-04-2009 06:24 AM
porcelain versus ceramic tile pandora Flooring 55 11-24-2008 10:01 AM
Porcelain on Cast Iron Tub controlnovice Plumbing 1 08-16-2008 11:36 AM
