Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 09-26-2012, 11:53 PM   #1
RedGard on Concrete floor before tiling?
Hi I was about to use RedGard on a long bathroom's concrete floor before tiling.
Was planing on using RedGard for crack prevention not for water proofing.
The Concrete is in pretty good shape just has a few hairline cracks that run across it. The floor is only about 22 years old. One crack is about 1/8 inches thick running across the floor and about 2 are about 1/8 inches thick. The rest of concrete seems like it's in good shape.
Does RedGard have to be applied all over the concrete? Or if I could just paint it over the cracks
Also after it is painted on, is it OK to walk on it for setting up the tiles and doing a dry run with the tiles? Or will I need to put construction paper down to protect the RedGard.
Also, I'm guessing if I do put RedGard all over the concrete it will be interesting putting the chalk marks and marking where tiles go....hmmm
crayola110 is offline   Reply With Quote
Old 09-27-2012, 02:59 AM   #2
Super Moderator
Redguard can be used as an uncoupling membrane---if you don't cover the entire floor---and just do the crack areas---make the band about two feet wide.
Once dry you can walk on it without an issue.
crayola110 (09-27-2012)
Old 09-27-2012, 01:27 PM   #3
Thanks Mike. I'm just trying to keep costs down as I would need to buy 2 gallons if I had to do the whole floor. I think I'll just do it over the cracks only. This crap is expensive! haha
Old 09-28-2012, 06:10 AM   #4
Super Moderator
I use Hydroban---almost twice as expensive----but for your use Redguard is a fine choice----Mike----
Old 09-28-2012, 01:49 PM   #5
sorry one last question do you have to create a primer by diluting 4-1 part water. I had read somewhere on internet someone did that, but wasn't sure since my concrete floor is fairly clean and just 22 years old?
Old 09-29-2012, 10:24 PM   #6
Super Moderator
Follow the manufactures instruction---they know better than a stranger on the internet--I'm a stranger-
Seriously---go to the maker----the more you know about a subject,the more you will see how much truly bad information is floating around on the web.
crayola110 (10-01-2012)
Old 10-11-2012, 06:35 PM   #7
Also, I'm guessing if I do put RedGard all over the concrete it will be interesting putting the chalk marks and marking where tiles go....hmmm[/QUOTE]
This is an easy fix. After you put your chalk line down spray line with hairspray wait to dry. Works great, try on any uncoupling membrane
Jimbo1 is offline   Reply With Quote
The Following User Says Thank You to Jimbo1 For This Useful Post:
oh'mike (10-11-2012)
Tiling kitchen floor (concrete) scotto87 Tiling, ceramics, marble 6 07-19-2012 08:16 PM
Tiling over VAT on concrete slab ajackson716 Tiling, ceramics, marble 5 09-22-2011 08:06 AM
tiling over a concrete joint dave60 Flooring 6 03-07-2011 08:33 PM
Tiling over new concrete 47_47 Tiling, ceramics, marble 2 12-12-2008 02:49 PM
Tiling a porch over a painted concrete surface Harls Building & Construction 1 07-14-2008 08:34 AM
