-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   RedGard on Concrete floor before tiling? (http://www.diychatroom.com/f84/redgard-concrete-floor-before-tiling-158109/)
crayola110 09-26-2012 10:53 PM
Hi I was about to use RedGard on a long bathroom's concrete floor before tiling.
Was planing on using RedGard for crack prevention not for water proofing.
The Concrete is in pretty good shape just has a few hairline cracks that run across it. The floor is only about 22 years old. One crack is about 1/8 inches thick running across the floor and about 2 are about 1/8 inches thick. The rest of concrete seems like it's in good shape.
Does RedGard have to be applied all over the concrete? Or if I could just paint it over the cracks
Also after it is painted on, is it OK to walk on it for setting up the tiles and doing a dry run with the tiles? Or will I need to put construction paper down to protect the RedGard.
Also, I'm guessing if I do put RedGard all over the concrete it will be interesting putting the chalk marks and marking where tiles go....hmmm
oh'mike 09-27-2012 01:59 AM
Redguard can be used as an uncoupling membrane---if you don't cover the entire floor---and just do the crack areas---make the band about two feet wide.
Once dry you can walk on it without an issue.
crayola110 09-27-2012 12:27 PM
Thanks Mike. I'm just trying to keep costs down as I would need to buy 2 gallons if I had to do the whole floor. I think I'll just do it over the cracks only. This crap is expensive! haha:laughing:
oh'mike 09-28-2012 05:10 AM
I use Hydroban---almost twice as expensive----but for your use Redguard is a fine choice----Mike----
crayola110 09-28-2012 12:49 PM
sorry one last question do you have to create a primer by diluting 4-1 part water. I had read somewhere on internet someone did that, but wasn't sure since my concrete floor is fairly clean and just 22 years old?
oh'mike 09-29-2012 09:24 PM
Follow the manufactures instruction---they know better than a stranger on the internet--I'm a stranger-:laughing:
Seriously---go to the maker----the more you know about a subject,the more you will see how much truly bad information is floating around on the web.
Jimbo1 10-11-2012 05:35 PM
Also, I'm guessing if I do put RedGard all over the concrete it will be interesting putting the chalk marks and marking where tiles go....hmmm[/QUOTE]
This is an easy fix. After you put your chalk line down spray line with hairspray wait to dry. Works great, try on any uncoupling membrane :thumbup:
