Ready To Tile? - Tiling, ceramics, marble - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-13-2012, 09:33 PM   #16
Originally Posted by JazMan View Post
There should be no 1/4" anything in a tile installation sandwich. Regardless, I think it would be a good idea to get down to the planks and refasten/repair as necessary. Chances are the planks are not t&g and the nails may have worked a bit loose by now.
What kind of shape is the 1/2" you're looking at? What was on it? I might consider leaving what you've got, just refastening if I thought everything was in good shape and didn't mind the extra height.
But let's see what other info you give.
I said;
I was asking for an answer. Did we ever talk about the framing yet?
We went in circles a little cuz in your first post I think you went into too many subject. You asked about; plywood types & thickness, concrete board, Ditra, thinset mortars, Lash, trowels, backbuttering, and large tile sizes. We can help with all those, but not all at once. So, let's start with the joists.
Size, spacing, unsupported span to the inch. Species and grade if at all possible. Basement, crawl space?
Jaz
The 1/2 ply is in excellent shape.. Pretty solid and level. Looks to me to be only a few years old (i bought the condo in 09) and the previous owners were only here 2 yrs. The old flooring was linoleum tile which came up easier than I expected and didn't leave much, if any, adhesive. I sanded the floor to clear up any residue.
Sry for jumping around topics. Since this is my first tiling job and a much delayed project, Im trying to get alot of info quick. Originally, I was told I could tile directly over the plywood with no problem. Then someone at the tile place suggested laying mesh over to get a better bond to the tile... which lead me to this site and research on the proper surface for tiling- and everyone was against tiling on wood.
I live on a ground floor condo built in the 60s..no basement, no crawl space. I don't know the exact dimensions or condition of the joists and subfloor. My question about the thickness was to get a better idea of the levels associated with a normal floor. As I mentioned, the height difference is pretty apparent so I wanted to know if there was a better option (i.e. cement board directly over the lowest level subfloor/ planks). This doesn't seem to be an ideal set up tho. So, the I think I will refasten the 1/2 ply which would give me more than enough support to lay the cement board then tile. I will have to figure out a solution to transition the different level of flooring. Any advise is very much appreciated!
esco5710 is offline   Reply With Quote
Patching ceramic tile floor due to change in cabinet footprint Sparco41 Flooring 0 08-18-2012 09:22 AM
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Tile ready It sounded good Tiling, ceramics, marble 5 05-31-2011 07:46 PM
Installed a new Styrene tub, getting ready to tile above. Durock, or hardibacker? J187 Remodeling 3 03-31-2009 07:49 AM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
