Re-tiling Tub Surrond - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 04-07-2011, 03:45 PM   #1
Re-tiling tub surrond
Hi, I have removed the 4 inch tile around the tub. Most of the sheet rock top paper came off as well. Before I put up the new tile do I need to coat/seal this surface with something. And what adhesive would you recommend. Thanks
Angelic-man is offline   Reply With Quote
Old 04-07-2011, 04:28 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 388
You should remove the wall board and replace it with a concrete backer board, then install your new tiles using a thin set mortar which comes in a bag.
More to it than that obviously, but that's the skinny.
Jaz
Old 04-08-2011, 12:44 AM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Is this just a tub, or is it a tub/shower combo?
Tiling a bathroom... with uneven floors dianaslik Flooring 14 01-23-2012 08:37 AM
unstable subfloor for tiling hohadcr Flooring 2 08-27-2010 12:10 AM
First tiling project, need some help DIYD Tiling, ceramics, marble 1 08-06-2009 06:15 AM
Tiling bathroom ivaiva Project Showcase 3 08-30-2008 08:24 AM
is this bad tiling or am I being fusy??? rodger_j Flooring 23 07-16-2008 03:44 PM
