Re: Drilling Into Ceramic Tile - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 01-06-2011, 12:44 PM   #1
Rewards Points: 150
re: drilling into ceramic tile
Hello,
I have #10 screws I need to be drilled into ceramic tile for a towel bar that is screwed directly to blocking inside a shower.
The towel bar instructions says that 1/8" drill bit is needed to accomindate the screws. That pilot hole seemed very small to me
After drilling 1/8" with a spade but, and tightening the screw with my hand, I don't see that screw going in without cracking the tile. I tried it on scrap piece, and sure enough, it shattered.
I drilled another scrap piece with a 3/16" spade, and the threads pass directly though.
Should I be using a 3/16" bit or a 5/32" bit which is in between 1/8" and 3/16" and the threads catch slightly. OR should the threads not catch the tile at all?
Also should I pre drill into the blocking behind the shower tiles?
-gramps
gramps416 is offline   Reply With Quote
Old 01-06-2011, 12:57 PM   #2
Handyman
Rewards Points: 512
Are you drilling holes for the towel bar mounting clips? If so you can use a wider bit (diamond tip) and slightly larger head screws. All of this will be be covered by the actual rack anyway. If there is no stud behind the wall I would suggest using toggle bolts. The screw threads should not touch the tile.
canadaclub is offline   Reply With Quote
Old 01-06-2011, 01:12 PM   #3
47_47's Avatar
Rewards Points: 58
Originally Posted by gramps416 View Post
Hello,
-gramps
As canadaclub stated, the screw should pass freely through the tile. A 3/16" hole. Be careful not to drill too deep, just through the tile. Use a 3/32" bit for the pilot hole into the blocking.
47_47 is offline   Reply With Quote
Old 01-06-2011, 02:26 PM   #4
Rewards Points: 150
It's more like a mounting ring that holds at least 3 screws.
Because this is a kerdi shower, there was extra width to the wall. I felt like 2" screws, seemed like they would not have enough bite into the wood. I bought 3" stainless steel screws. Is that okay? My blocking would be 1 1/2" thick
Old 01-06-2011, 04:30 PM   #5
Handyman
Rewards Points: 512
thats what I figured..no need to be anal about instructions..moreover make it secure. Manuals always include "neccessary" hardware for installation but 9 times out of 10 they supply the least of material to cover their behinds.
Old 01-06-2011, 05:48 PM   #6
DIY staff
Rewards Points: 7,174
I use 1/4 inch diamond for porcelain-- Carbide for softer tile---Buy the diamond ones by the dozen on Ebay--
Old 01-06-2011, 07:15 PM   #7
Handyman
Rewards Points: 512
That would support a towel rack just fine. You mention its a Kerdi shower...If you are mounting the rack inside the shower stall you need to make sure to use silicone caulk when driving the screws in and clear caulk around the outside of the mount brackets before you hang the rack up.
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 08:50 PM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 06:08 PM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 06:12 PM
drilling in ceramic floor tile mrmac204 General DIY Discussions 4 04-14-2008 09:27 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
