-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   re: drilling into ceramic tile (http://www.diychatroom.com/f84/re-drilling-into-ceramic-tile-91524/)
gramps416 01-06-2011 12:44 PM
Hello,
I have #10 screws I need to be drilled into ceramic tile for a towel bar that is screwed directly to blocking inside a shower.
The towel bar instructions says that 1/8" drill bit is needed to accomindate the screws. That pilot hole seemed very small to me :eek:
After drilling 1/8" with a spade but, and tightening the screw with my hand, I don't see that screw going in without cracking the tile. I tried it on scrap piece, and sure enough, it shattered.
I drilled another scrap piece with a 3/16" spade, and the threads pass directly though.
Should I be using a 3/16" bit or a 5/32" bit which is in between 1/8" and 3/16" and the threads catch slightly. OR should the threads not catch the tile at all?
Also should I pre drill into the blocking behind the shower tiles?
-gramps
canadaclub 01-06-2011 12:57 PM
Are you drilling holes for the towel bar mounting clips? If so you can use a wider bit (diamond tip) and slightly larger head screws. All of this will be be covered by the actual rack anyway. If there is no stud behind the wall I would suggest using toggle bolts. The screw threads should not touch the tile.
47_47 01-06-2011 01:12 PM
Originally Posted by gramps416 (Post 564068)
Hello,
-gramps
As canadaclub stated, the screw should pass freely through the tile. A 3/16" hole. Be careful not to drill too deep, just through the tile. Use a 3/32" bit for the pilot hole into the blocking.
gramps416 01-06-2011 02:26 PM
It's more like a mounting ring that holds at least 3 screws.
Because this is a kerdi shower, there was extra width to the wall. I felt like 2" screws, seemed like they would not have enough bite into the wood. I bought 3" stainless steel screws. Is that okay? My blocking would be 1 1/2" thick
canadaclub 01-06-2011 04:30 PM
thats what I figured..no need to be anal about instructions..moreover make it secure. Manuals always include "neccessary" hardware for installation but 9 times out of 10 they supply the least of material to cover their behinds.
oh'mike 01-06-2011 05:48 PM
I use 1/4 inch diamond for porcelain-- Carbide for softer tile---Buy the diamond ones by the dozen on Ebay--
canadaclub 01-06-2011 07:15 PM
That would support a towel rack just fine. You mention its a Kerdi shower...If you are mounting the rack inside the shower stall you need to make sure to use silicone caulk when driving the screws in and clear caulk around the outside of the mount brackets before you hang the rack up.
