Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 01-07-2011, 08:12 PM   #1
Questions about Installing Schluter Shower Kit
My mother-in-law is in need of a new shower base and tiles (leaks). While I am confident in my tiling abilities, I would like to install a Schluter kit to remedy any leaks she has. Since I have not installed one before, my questions are 1) How long does it take to install the kit? 2) what is involved in making the appropriate drain connection? Thanks!
dgeorge is offline   Reply With Quote
Old 01-08-2011, 07:31 AM   #2
lots of kerdi info here:
http://www.johnbridge.com/vbulletin/index.php
should take 2 days depending on ability
is the shower on concrete or on plywood floor
if plywood the drain installation won`t be much of an issue. if on concete, you will have to break into the conrete by a few inches to allow for the kerdi drain.
williamwiens is offline   Reply With Quote
Old 01-08-2011, 10:00 AM   #3
Experienced
Jackofall1's Avatar
You say the shower has leaks, I would be more concerned at how long it will take to repair the damage from the leaks, more than how long it will take to install a prefab pan.
Old 01-08-2011, 03:42 PM   #4
The pan is on a second floor plywood substrate. The trick will be getting everything out and the new drain connected because there's no access to it from below or the side.
Old 01-08-2011, 03:45 PM   #5
I should have been more clear. It has leaked in the past where the original installer's caulking failed. in any event, the whole thing will come out, as well as the wall tiles and drywall behind it. That way, I can inspect the whole are well to see if she has any further damage hidden beneath. Fingers crossed it will be ok. I have done other tear outs in her house and have not yet found any significant hidden damage to studs or anything elese. Again...fingers crossed!
A few quick questions about redoing a shower Swazzle Remodeling 1 08-02-2010 11:06 PM
Schluter Kerdi shower system...help! secutanudu Kitchen & Bath Remodeling 3 07-18-2010 07:49 PM
Questions on waterproofing tile walls for shower with floor pan. HautingLu Tiling, ceramics, marble 11 09-18-2009 12:12 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 11:42 AM
installing lights in shower stall mcvane Electrical 2 03-30-2007 06:34 AM
