-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   Question for JazMan - Subfloor / underlayment - Ceramic Tile (http://www.diychatroom.com/f84/question-jazman-subfloor-underlayment-ceramic-tile-97119/)
benr 03-03-2011 12:12 PM
Hey JazMan, you seem to be the go to guy around here for these kinds of questions so your advice would be very much appreciated. Anyone else, feel free to chime in.
I am building a house (you answered a question for my bamboo underlayment here) and I am going to be tiling my foyer, and bathroom.
I have 5/8 subfloor on 16"o/c eng. joists. I am wondering what to put down before my tile.
1/2" cement board? 1/4 or 3/8 plywood and then 1/4" cement board? What is the best way? Most economical way, while still obtaining a quality base?
I assume the min thickness is at least a 1inch or more for tile. I am sure you have answered this before but I didn’t come across yet, so I figured I would make a new post.
Thanks,
Ben
JazMan 03-03-2011 11:26 PM
Hi Ben,
Thanks for your confidence, but truth is there are a bunch of other tile pros that devote lots of time and know their stuff.:thumbsup:
I think it's safe to say that we all think 5/8" t&g plywood subfloor stinks. I don't think much of a builder that strives to build floors to the lowest standards allowable. However, 5/8" ply subfloor does meet specs as the subfloor. Of course the fine print also says, (or used to say) that the floor assembly must meet L360 deflection, which is again the most allowable deflection for ceramic/porcelain tiles. How does one know that? You don't.
As for your subfloor sheets I would add as thick a plywood sheet as possible, min. 3/8". I would then recommend Ditra membrane or one of Noble's sheet membranes. Alternatively a basic 1/4 or 5/16" concrete backer is fine too. Then the tiles.
I guess your eng. joists are I-joists. They are usually designed to rate no higher than L480, which is better than L360. Since the house will be inspected, we can gather you should be better than L360. Double check with the maker and tell them you want the floor's load rating should be at least 50/20 lbs per. sq. ft. Do not accept a deflection rating that calculates the load at the basic 40/10. (minimum code these days.)
If you can go with one of the above, why not go with 1/2" B/C ply and then Ditra.
NO. The minimum ply thickness is 5/8", to me 3/4" is min. But... the more the better.
Jaz
