Question About Tile Leveling Systems - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 04-13-2015, 12:13 PM   #1
Rewards Points: 4,780
Question about tile leveling systems
I've never used one of these, although I plan on it at some point. I can do a the research myself, but if anyone has a strong opinion on one product or another, let's hear it.
But regardless of the system, my question about these is this, and I'm not sure why I haven't heard any mention of this one way or the other. Let's just assume a straight square pattern. Normally if there is lippage, I would do one or both of
- push down the high corner of a tile, embedding it further into the thinset, or
- lift a tile and add thinset under a low corner, ensuring that the corner were fully supported.
The problem I have with these tile levelers is that, in theory at least, you are going to be lifting a corner of tile up away from the thinset, and that corner of the tile is going to be unsupported. Isn't that a really bad thing to do in theory? Maybe it's not an issue in practice because it's difficult to stand on that little corner of tile and put much pressure on it because you're really standing on the other 3 tile corners at that intersection, which are presumably fully supported.
jeffnc is offline   Reply With Quote
Old 04-13-2015, 07:05 PM   #2
DIY staff
Rewards Points: 7,174
I use the 'Lash' system----perhaps there are better systems,but i have the parts and never saw a need for the more expensive Tuscan system.
Some times you do need to build up the thinset--however--the clips seem to pull the high tile DOWN rather than lift the low tile--
All I know is this--with the popularity of the jumbo sized tiles---your life will be easier if you use the system--
Tub Tile Surround Question GrooveMerchant Kitchen & Bath Remodeling 15 11-26-2011 10:01 PM
Glass Mosaic tile Question, cutting and grooved trowel ryan5068 Tiling, ceramics, marble 3 11-20-2011 11:33 AM
Tile on Concrete Slab + Radiant Heat Question still lost Flooring 11 11-17-2011 11:26 AM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 08:48 PM
Backerboard and Tile Project Question Livestrg05 Flooring 6 04-25-2009 08:35 AM
