Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 01-14-2010, 10:51 PM   #1
Pull up vinyl floor or leave it down?
I have vinyl flooring over luan (1/8 or 1/4", not sure which). I want to do porcelain tile.
I've talked with a few contractors about this. The first two didn't say a word about going directly over the vinyl with the backerboard, yet the third is insisting that I rip the vinyl up or I may have problems. My floor doesn't squeak or have any issues that I can find.
Is the guy who wants to rip the vinyl up just being overly cautious?
Zinger is offline   Reply With Quote
Old 01-14-2010, 11:09 PM   #2
Tileguy
JazMan's Avatar
It's not clear what the three are proposing. Just removing the vinyl isn't enough, the lauan has to go too. Squeaking has nothing to do with anything here. You don't want the vinyl or the lauan.
Once you're down to the subfloor and it's in good condition, they'll install either a backer board into fresh thin set mortar, etc.
Have any of these fellas confirmed that the subfloor system is good enough for tile installation? That would be the sheets and the framing.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 01-14-2010, 11:17 PM   #3
firehawkmph's Avatar
Zinger,
You got one shot to have the job done right. I am not one to cover things up and make bigger problems down the road for the next guy. The installer that wants to get rid of the luan and vinyl is giving you good advice. This is all dependent on what's underneath as Jazman stated. I personally wouldn't lay the tile over the vinyl/luan. I don't want to chance something going wrong later on when I had the chance to correct it up front.
Mike Hawkins
firehawkmph is offline   Reply With Quote
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
vinyl sheet or tile (or allure) over old vinyl? thomase Flooring 8 06-30-2008 06:15 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
