Preparing To Tile Floor - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-29-2012, 05:16 PM   #1
Preparing to tile floor
This is a simple question. What trowel do I use for spreading the thin-set over the cement board to secure the porcelain tile?
The sub-floor was flat and cement board has been screwed down with thin-set applied to secure it. The seams were taped and filled with thin-set. A floor warming mat partially covers the floor. The 12 X 12 porcelain tile is a quarter inch thick. I will be using Versabond fortified thin-set.
avoidblunder is offline   Reply With Quote
Old 02-29-2012, 08:54 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 220
Hi,
There's a few things that apparently you haven't learned yet and I hope you know more than what it appears you do at this time.
First, to accurately answer your question you also have to tell us at minimum the thickness, and size of the tiles. There's more info that would help too. Like how flat if the floor? Did you check that? How about the framing and subfloor?
Also you have to spread thin set under the cement board, fasten and tape. What specific thin set will you be using?
Jaz
Old 03-01-2012, 07:13 AM   #3
Pro
JetSwet's Avatar
Rewards Points: 502
A 12x12 tile can be used with a 1/4x3/8 notched trowel.
Jaz, looks like op has already said what thin set being used and tile size.
JetSwet is offline   Reply With Quote
Old 03-01-2012, 07:36 AM   #4
DIY staff
Rewards Points: 7,174
He added it to the original post by editing---Mike---
Old 03-01-2012, 12:01 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 220
AHA........he was trying to trick me.
OK good, I agree the 1/4x3/8x1/4 is the best choice. I see you also edited that you spread thin set under the CBU and seams taped.
How are you gonna deal with the 1/8+ thickness of the warming mat on part of the floor?
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
JetSwet (03-01-2012)
Old 03-01-2012, 01:12 PM   #6
I agree the 1/4 x 3/8 notched trowel would be sufficient to lay the tiles, but you will have to either back butter the tiles that are not over the warming mat to bring them up to the same height or self level the whole floor before tiling.
socalsteve72 is offline   Reply With Quote
Old 03-01-2012, 01:58 PM   #7
Pro
JetSwet's Avatar
Rewards Points: 502
I guess back butter won't hurt... I don't think it has much to do with hight though.
Maybe JazMan can answer that better as I only butter wall tiles 13x13 or bigger.
Old 03-01-2012, 04:10 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 220
Back-buttering isn't going to remedy the floor issue. I suspect the OP was going to apply SLC or something to make the floor flat first......hopefully.
Jaz
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 02:46 PM
Porcelain tile over linoleum floor Jac121 Flooring 11 01-06-2012 08:32 AM
Installing floor tile but don't want grout gap to turn black overtime gatorade Flooring 4 02-07-2011 12:13 AM
Filling in space left after floor tile removed for drainage system phillylex Flooring 3 01-26-2011 08:47 AM
