Possible Problems With Cracking? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 10-14-2008, 08:53 AM   #1
jkm
possible problems with cracking?
I am currently installing my first tile job, which is around 360 sq ft. from the kitchen into a bathroom and a utility room. my problem is that I am more than halfway finished and my floor is a quite unlevel in a few places. ie. behind the fridge. I am using a 1/2" X 1/2" to lay my thinset with 20x20" tile; the tile appears to be sturdy but I was needing to know if I have set myself up for trouble down the road for cracked tiles; if so how long would it be until I started seeing this?
jkm is offline   Reply With Quote
Old 10-14-2008, 12:27 PM   #2
SM1
SandMasters ProFloorCare
SM1's Avatar
the rule of thumb is the more variation in your floor, the smaller a tile you want to use. 20x20 tiles will show kickers like no other... if you can get a 12x12 you'll be way better off.
SM1 is offline   Reply With Quote
Old 10-15-2008, 10:11 PM   #3
Tile Setter
Even when the subfloor is out of level or not exactly flat, you can still lay tile flat either by screeding the low spots ahead of time, or building up with the thinset while tiling.
If your tiles are uneven with eachother, there is little that can be done aside from tearing them up. Having tile set uneven and with lippage will not in and of itself cause cracking. There are a host of other factors that could cause cracking, one being coverage under the tile. If there are areas under the tile where you do not have thinset supporting the tile, that will be a weak spot. Beware of rolling anything over or dropping anything on that spot.
- Bob
Tileworks is offline   Reply With Quote
Old 10-17-2008, 07:53 AM   #4
jkm
thanks
thanks for the replies so far; I do have some lippage, but nothing that makes things look bad. I may try and post some pics sometime soon, and if anyone out there has anything to add on this tiling subject please do, I am always willing to learn as much as possible.
Old 11-09-2008, 02:20 AM   #5
back butter them,that will help
detroitMi is offline   Reply With Quote
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 01:51 PM
Elec short causing A/C problems or A/C problems causing elec problems? Marlon Electrical 2 06-25-2008 02:04 PM
phone problems AStott Electrical 13 06-07-2008 06:27 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
