Porcelian Tile - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 09-18-2010, 01:42 PM   #1
Porcelian Tile
What size variance is considered acceptable for 16x16 porcelian tile? They are running 1/16 inch to 1/8 inch variance between tiles.
Gene Call is offline   Reply With Quote
Old 09-18-2010, 03:52 PM   #2
DIY staff
Rewards Points: 7,174
Those are not very good numbers---As far as acceptable industry standards, Tiles can be as accurate or sloppy as can be---Now that you found the problem,as the installer it is up to you to accept the slop or return them.
Unfortunately, Most manufacturers limit their liability to the cost of the tiles--with a phrase like ,
"It is the responsibility of the installer to inspect tiles before installation"---Good luck,sounds like you have a bad batch of tiles.----Mike---
Gene Call (09-19-2010)
Old 09-19-2010, 03:07 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Are you talking about new tiles fresh out of the box that are varying sizes and not yet installed? I hope!
XXX
Old 09-20-2010, 07:55 AM   #4
Yes...I opened several boxes and laid them dry. That is when I found the variance. It appears my order was filled with more than one run/lot.
I am returning them and will try to get all my tiles from the same run/lot. Maybe that will take care of the variance, if not I will try another manufacturer.
Old 09-20-2010, 03:45 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What you are finding is going to be typical. The tiles usually aren't exact in size but a 1/8" variance is extreme.
What you want to buy are "rectified" tiles. They will be your best-bet for size consistency. Try a real tile store and tell them you want rectified tiles no matter what.
Most tiles available are not rectified.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
Gene Call (09-20-2010)
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 09:07 PM
Cutting Porcelian Tile without chips BruceStone Building & Construction 3 02-01-2008 04:33 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
