Porcelain Installation On Concrete With Ditra - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-01-2012, 01:13 PM   #1
Hi all! So, I'm installing porcelain tiles on concrete using Ditra underlayment. The Schluter instructions specify unmodified mortar for layers between concrete and Ditra, as well as between Ditra and the tile. I've been reading that many installers still use modified for both mortar layers, leaving a day to allow proper curing. Is this still thinking applicable to concrete? Or only for a wood subfloor?
jracks3 is offline   Reply With Quote
Old 08-01-2012, 04:01 PM   #2
Pro
JetSwet's Avatar
Rewards Points: 502
Unmodified needs air or moisture to cure modified doesn't.
I think the reason they say to use unmodified is for concrete install as pose to cbu board to use modified.
JetSwet is offline   Reply With Quote
Old 08-01-2012, 05:49 PM   #3
DIY staff
Rewards Points: 7,174
You got that backwards---Modified needs some air to cure---unmodified does not---
I'll leave this to a Ditra user--
Old 08-01-2012, 06:02 PM   #4
Pro
JetSwet's Avatar
Rewards Points: 502
I did, sorry little backwards today I should have left alone the way this days been going eeeek
http://www.schluter.com/5891.aspx
Old 08-01-2012, 06:11 PM   #5
DIY staff
I know the feeling---open mouth --insert foot---
JetSwet (08-01-2012)
Old 08-01-2012, 08:55 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 412
As you stated, you should use an unmodified mortar to set tiles on Ditra. Also use the same mortar to install the Ditra to concrete. It wouldn't hurt at all if you used a modified to install the Ditra. Something like Versabond, which is an entry-level mortar available at the orange place.
Many people have a fear of not getting a good bond when bonding porcelain using unmodified. They mistakenly think unmodified will not bond to porcelain. Generally you would indeed use a modified when setting porcelain over anything, but Ditra isn't just 'anything". So if you don't need a warranty, (I don't care about them), or can't find a good quality unmodified where you shop, go ahead and use a basic modified to set the tiles. Otherwise if you can find Ditraset or any high quality unmodified, go that way.
What specific unmodified mortar can you get near you?
Sure wish people would say where the heck they're located, it would be mandatory if I ran this place. and, it would be a better place.
Jaz
Old 08-01-2012, 09:19 PM   #7
DIY staff
I do try to get locations---
Old 08-01-2012, 09:28 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 412
I know you do Mike, thanks for that. But it needs to be required when registering and before posting. It sure would help.
Jaz
Old 08-02-2012, 01:11 PM   #9
Jaz,
Thank you for the insights. I'm in Palatine, IL, which is a northwest suburb of Chicago. I have an account at ProSource where they are able to get me a quality unmodified. I actually can't find it anywhere else except big box or small e-commerce online with crazy shipping charges. Anyhow, I can get the unmodified, but I've been getting the feeling that people don't like it. My tile installer has never used it. I've been researching this on my own, as I want it done right and have the means to make sure it is done that way.
Jamie
Last edited by jracks3; 08-02-2012 at 01:13 PM. Reason: quality unmodified mortars I was looking into were Tec Full Set, Durabond Ditra-Set and Mapei Kerabond
Old 08-02-2012, 01:18 PM   #10
DIY staff
Kera Bond is available at Menards---Mepei---
Old 08-02-2012, 01:32 PM   #11
Yes, it is but the lead time for delivery is 2-3 weeks.
Jamie
Old 08-02-2012, 01:59 PM   #12
Does anyone have a preference between the unmodified mortar options- Kerabond, Ditra-Set or Full Set?
Old 08-02-2012, 09:10 PM   #13
Tileguy
JazMan's Avatar
Rewards Points: 412
Those are all good quality dry-set thin set mortars. I would select Ditraset though. Another good one, which I'm using for the first time on the current Kerdi shower job is Custom's Uncoupling Mat mortar. I can't tell the difference between it and Ditraset.
Palatine, chances are there's lots of Tec's Full Set, since it's made in nearby Aurora.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
jracks3 (08-03-2012)
Tags
concrete subfloor , ditra , mortar , porcelain tile , unmodified
Porcelain tile over particle board over concrete slab? roughtrader Flooring 9 04-16-2012 11:24 AM
Rectified Porcelain, DITRA, and unlevel surface tips superspeck Flooring 2 07-27-2011 07:05 PM
ditra concrete and vinyl hab Flooring 0 04-06-2010 10:00 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
Problems with Porcelain over Radiant Concrete Scarlo Flooring 3 12-29-2009 02:45 PM
