Pool Patio Tile Help Needed - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-29-2012, 08:01 AM   #1
I have a patio made of mexican tile around my pool ( more than 800 12 x 12 squares). I live in Southeast Arkansas, and though our winters are not too harsh, we do get below frezing temperatures. Because these tiles are sun dried and porous, they tend to crack and chip (alot) due to the changes in temperature. Is there any product I can apply over the tile to help prevent this. These tile have been down about 30 years and the best I can tell are on a sand base.
cpelliott is offline   Reply With Quote
Old 03-30-2012, 12:29 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 340
No, there is nothing you can do to keep them from absorbing moisture. What has saved them so far is the sand base which allows most of the water to soak into the earth. Definitely the wrong type of tiles for your location.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
cpelliott (04-06-2012)
Old 04-06-2012, 07:40 PM   #3
Jaz Thanks for your response. Any suggestions of an easy, cheap DIY pool surround that will hold up to the climate in Southeast Arkansas.
CPElliott
Old 04-09-2012, 12:06 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 340
I guess brick type pavers would be a good choice. Something to consider plus the base might be already prepped.
Jaz
Old 04-10-2012, 05:33 PM   #5
Thank you foR the advice.
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 11 12-30-2013 09:30 AM
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 08:03 PM
ceramic tile outdoor patio wood deck bairdex Tiling, ceramics, marble 2 11-26-2011 04:28 PM
Tile Experts - Input Needed! CapnHawk Kitchen & Bath Remodeling 4 03-26-2011 04:12 PM
What's Needed for Drain Tile / French Drain samsmith Building & Construction 2 08-24-2010 11:20 AM
