Please Help With Bathroom Tile - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 11-10-2009, 04:00 PM   #1
please help with bathroom tile
i realy hope you all can send me in the right direction.
i just purchased my first house a year ago and gutted the second bathroom.never doing any of this before, i figured i would just learn and figure it out as i go.
i got the sink pipes where they should be, jacuzi tub anb plumbing in,drywall up and mostly all taped and mudded. and the hardy backer for behind the tub.
heres where i am stuck.
#1 do i tape and mud the hardybacker were the tile is going??
#2 where the hardybacker meets the drywall, what material do you use to join the two????
thanks for any help.
this has been a 8 month jurney, and my preg. wife wants her bathroom back.
jim
fishtale is offline   Reply With Quote
Old 11-10-2009, 04:59 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The seams of the Hardi should be taped with mesh alkali resistant tape and bedded with thinset mortar.
The juncture between the Hardi and the drywall can get tedious. Try to locate that joint so that it is covered by tile. If so use thinset there also. If not, you'll want to use joint compound but tile mortar doesn't necessarily like joint compound. Just depends. I always use thinset and any thinset that is flashed into an area to be painted is then covered and prepped with joint compound after the tile goes in.
XXX
Old 11-10-2009, 05:57 PM   #3
dang,i have the backer board exactly where the tile will end.
and the hardi has a perfect edge, but the drywall meeting up to it is not cut good, itskinda wavy, and theres some gaps that need filled in with something. should there be tape there??
thanks,
jim
Old 11-11-2009, 04:54 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 346
Yes Jim all seams must be taped and either thin set or drywall compound applied. As Bud said, try to avoid compound under the tiled areas.
Jaz
Old 11-13-2009, 07:28 AM   #5
so where the backer and tile end and meet the drywall, i should use thinset and paper tape to join the two?
how does that work out? the 1/2"drywall is thicker than the 1/2" hardi
Old 11-13-2009, 03:20 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
James Hardi Company in their infinite wisdom has chosen to produce a backeboard that is actually 7/16" thick but have chosen to call it 1/2", hence the Hardi 500 designation.
The small 1/16" variance has never been a real issue. Under the tile no one will know the difference anyway. Feather it out with thinset if need be. I wouldn't use paper tape, use mesh tape.
XXX
Old 11-15-2009, 06:30 AM   #7
thanks.
let ya know hoe it goes
Removing Bathroom Ceramic Tile Laid in 1970 mark2741 Flooring 6 12-08-2011 08:55 AM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 06:08 PM
Bathroom tile question aumanpj Building & Construction 66 07-18-2009 11:43 AM
Patch a hole in the bathroom tile sw41 Flooring 1 12-07-2008 12:57 PM
Bathroom wall tile Ricksweares Flooring 10 02-26-2008 03:16 PM
